Can anyone Help ME... I bought a Timing belt with NO timing Marks... Does someone KNow how to Time this Model? Or where can I buy a timing belt with the marks?
PLease HELP
LD20-II Timing Info
I dont know.
i found that you couldnt get the cam possition wrong as valves hit the pistons..
im certian that the cam dowl or a mark on the cam lines up when you have the top cover off.
the cam timing gear marks are parrallel with the IP pump marks.
i used the tacho pulse chopper wheel to find TDC but after i found the timing mark on the front oil pump case.on water pump side.
