Gen1 1981 Car randomly doesn't seem to get enough fuel.
thane
Car will randomly die while driving. Often at full speed but occasionally around town at low speeds. If you keep the gas pedal floored it will usually keep moving but only at a very slow rate. (won't even go up a slight incline if you don't already have momentum) As soon as you let off the gas pedal it dies completely.
Usually the car will start back up again if you keep the gas pedal floored and the starter cranked for a long time. It sort of starts slowly and then if you keep the gas pedal floored it will eventually get enough fuel.
Occasionally, it will start back up but still not get enough fuel to actually accelerate.
I can't figure out what is causing this and my mechanic doesn't know either.
Anyone have any idea what could be going on?
thane
Fuel filter? If that's it, be careful-- running it too long with it clogged to that point can damage the IP internal vane pump.
Try draining the fuel filter to get an idea of what's in there. You will probably have to purge the air from the fuel system after that. Might as well change the fuel filter. How long has it been?
charmalu
If your mechanic can`t figure it out. better dump him. need a mechanic that understands Diesel engines.
A Diesel engine needs 3 things.
1) Compression
2) Air
3) Fuel
Take one of them out of the loop, and it won`t start.
The following 2 are also helpful.
4) Working Glow Plugs
5) A fully charged battery to spin it fast enough to start.
Most problems with Diesels is usually a fuel problem. no fuel, plugged filters, sucking air through a fuel hose or fitting.
Replace the fuel filters, and should be good to go. fill the filter first before screwing it on. this will lessen the air to purge.
Do not use the fuel from the old filter to fill the new one. I have heard of this being done. Use Lubro Molly Diesel Purge, ATF or clean Diesel fuel to
fill the filter.
Charlie
1) Compression
2) Air
3) Fuel
fill the filter.
Charlie
78 240D Mercedes $300 Parts?
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
86 Ford F250 6.9 Diesel 221K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
thane
No, it's not the fuel filter. That is one of the first things we replaced. We even added another fuel-pump thinking that the original one might not always be pushing enough fuel.
I should also note that this has been happening for at least the 5 years I've owned the car and possibly the life of the car.
It usually happens when the car is low on fuel. At about a 1/4 tank or less.
thane
diesel-man
thane
It doesn't ever do it multiple times in a row. If it happens letting it sit overnight always fixes the problem. Or if it starts back up then it doesn't happen again. It can be days, weeks months in between having a problem.
Thank you so much for the information. I will give some of your suggestions a try.
thane
charmalu
Iam wondering if there is something in the tank floating around, and when the fuel level gets low, the pick up tube sucks it up. then when you turn the engine off, it floats off.
I was also thinking maybe the vent line from the tank could be plugged causing a vacuum in the tank. that would be an all the time thing, not random. HMMMM, I don`t know.
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
HAH!charmalu wrote:Iam wondering if there is something in the tank floating around, and when the fuel level gets low, the pick up tube sucks it up. then when you turn the engine off, it floats off.
Please read stories #3 and #2 (in that order) in this post!
Probably not thane's answer, but an odd coincidence that you mentioned those.
thane, you might try installing a length of clear vinyl tubing between the filter and the IP, and looking for entrained air. Don't leave the tubing there for weeks and weeks, but for a few days diagnostic you should be OK. The stuff is not heat resistant.
thane
I worked on a Toyota diesel PU a couple years ago that would only run if fuel was pushed to it by an external electric pump, and it had no power.
I determined that the IP's internal lift pump had failed. I had the IP rebuilt, and all problems went away.
If you want to read the story, and see the pics of the damaged internal lift pump, look here.
charmalu
Interesting stories. we keep adding these stories and situations to our mental book, every once in a while I flip to the right page
I remember hearing back in my High School days, of guys putting in pieces of seran wrap in the tanks for a prank.
It`s good the vent line on these 720`s in on the firewall. can`t imagine it being behind the front bumper. I know on the mercedes W123 & maybe a few other models. the vent is just to the inside of the R/R wheel.
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
