LD20 which gearboxes fit??
coldturkey
Post by coldturkey »
Hi,
I have cooked my LD20t Automatic Transmission and I am looking for a replacement.
The vehicle is a Nissan Largo van. I have heard that all L series gearboxes, including LD28 and L20 will fit.
However the LD28 gearbox I am looking at is a different length and is different all together, the rear mount is also on the bottom, not on the top of the box.
Can someone clear up what will work and what wont?
Many thanks,
Lawrence
largo---is this euroean built spainish van C23.
most of these are newer full electric controlled box
C22 has the older hydrolic box with an addon overdrive.
look at the van id plates.jap vans have gearbox id code number.
RE### is an electronic box.
the van gear box has mount in top of the short rear casing.and most can be swaped,these come in 2 shaft dia and a few diferent speedo drives. im told as ive only seen large diam.
