,,,so a no go for the LD28 for the OP?exmod110 wrote:I think the Nissan will be under powered for what you want it to do. u need more torque then the ld can produce with out being turbo'd... and if ur gonna do that u might as well just drop the cummins or isuzu in it. the lower end torque of the cummins will way out perform the nissan even turbo'd in ur application.
What is the Weight???
