NEED RADIATOR FOR STUCK IN KANSAS!!!!!!!!
alijena2319
Post by alijena2319 »
I am writing this for my brother hit a calf and smashed radiator for his 1982 SD22 720 King cab Pickup.... DOES ANYONE KNOW OF ANY SWAPS Parts interchange in or around KANSAS City ..... need to buy or find radiator for truck ASAP!!!
charmalu
Post by charmalu »
You may be able to pull from the junk yard from a gasser and have a radiator shop swap the top and bottom tanks. the radiator hose necks are in a different location.
I don`t think new radiators for the Diesels are still available. I thought I needed one last summer, and was checking the on line parts houses. nothing is listed for the Diesel, but plenty for the Gassers. maybe through the dealer, but hang onto your wallet.
I thought my 29 yr old radiator finally gave up the ghost. turned out that the rubber gasket in the cheap crappy 29 yr old radiator cap split and was blowing coolant. can you believe that? :shock: :D
Replaced the cap and all is good for another 29 yrs.
Charlie
78 240D Mercedes $300 Parts?
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
86 Ford F250 6.9 Diesel 221K
