1981 720 Std cab 98k miles.
Started leaking diesel from top of IP (where injector lines leave the pump). Bosch KiKi pump.
Is there "O" rings/gasket that can be replaced? If so source?
Stopped the leaking by tightening the joints that go into the pump but think they will start leaking again!!
Thanks in advance.
Injector lines leak
- Gubernaculum
Injector lines leak
J M Hellman
81 Datsun 720 2 wd
09 Z71
06 Kubota 5700
04 Yamaha Raptor 660
07 Yamaha Rhino 660
02 Polaris 500 HO Sportsman
07 Lexus ES 350
02 Australian Shepherd
81 Datsun 720 2 wd
09 Z71
06 Kubota 5700
07 Yamaha Rhino 660
07 Lexus ES 350
probably wont leak again. There is no "O" ring there but a tapered ball that is squeezed into a socket. As long as neither surface has a scratch or mark in them keeping them tight will stop the leak.
