sd25 nissan engine smokes badly
mark vancleve
Post by mark vancleve »
I already had the injectors replaced and air filter.but I still get a lot of white smoke at start up. The motor has under 50,000miles. Please if you have any ideas what I can try next. Thanks
Mark vancleve
michael3006
Post by michael3006 »
White smoke at start up is unburnt fuel.
Running your glow plugs for a longer time will help.
sidevalve
Post by sidevalve »
check your IP timing
!987 toyota 2wd pick-up with a SD22 from a 82 720.
