HAs anybody put Air conditioning on to an SD engine? I'm in the middle of building my truck from the frame up and want to add air onto my build.
Any help would be appreciated.
Dan
SD22 air conditioning add on?
My '82 has it - stock.
I've seen many photos of SD22-mounted A/C. They all look the same.
FSM accurately shows most parts & locations.
I had to pull the heater to replace 37 year old gaskets on the divert it flap to stop cold air poring into the cab.
That also helped with summer heat.
Massive A/C compressor mounts massively interfere with maintenance. Boo-hoo.
I'll flush it and replace all the hoses and seals one day so it works again - after I have the Injector Pump repaired. Priorities.
You want photos of it? I'll shoot some & post 'em on this thread.
SHALOM!
SHALOM!
'82 Datsun 720 SD22, '81 Toyota HiLux (proj)'77 Fiat 124 Spider trike project.
The Blessing of Abraham is mine.
Re: SD22 air conditioning add on?
I would love to see photos of it. I live in Hell,,,, I mean Georgia. Its 97 million degrees here!!! I need AC badly!!!
