Sold: Gast electric vacuum pump, 12v, $100
Perfect for your diesel conversion, Electric Vehicle (EV) conversion, or old-school rod that lacks enough idle vacuum to run the accessories & power brakes. These run about $290 from EV suppliers like KTA.
This is a Gast 12v vacuum pump, model MOA-V111-JH. Add a vacuum switch and reservoir, and this can supply the vacuum that your brakes, cruise control and HVAC needs. It can replace the vacuum pump that's built on the back of your Hitachi alternator, allowing you to replace it with any alternator you like. Or use it for your DIY sex toys ;)
Some specs are in this PDF.
Image Image Image Image Image
Shipping from US ZIP 98019.
It's best if you email me, as I don't check in here often anymore.
I sold this on eBay, got $125.
