This is a helpful thread for the SD-22 so I'll add this info. Shortly before my CN-33(marinized SD-22 by Chrysler) died, I had the injectors rebuilt. Now with an 84 SD-22 in my boat as a replacement, I decided to switch these into the SD.
With the right part # I got the nozzles at a forklift supply, New England Industrial Truck out of Ma. Part # NI 16635-J2000
The SD injectors looked like they'd been there for a long time, maybe never removed(this engine has low miles and was stored).
The first gasket was murder. I bought some steel Picks at my hardware store(see package in photo). After reading the nightmare of losing a tip on this thread, these are strong(I couldn't bend one with pliers). It took a good half hour to finally loosen and remove the first gasket with the various picks. This is the only nozzle visible(engines in a boat). The second, under the deck, took even longer.
Then I took the 90 degree pick on the left in the photo, and filed a sharp bevel with a fine file. The edge, flat, is like a small chisel or pry bar.
At an angle, the 90 degree end just fit inside the nozzle center bore, the bend or knuckle rests on the gasket above.
Slide it up until you feel the edge of the nozzle(easy), and pry. Voila. The last two nozzles loosened on the first try, and came out hanging on the pick. You can see the single mark it made on the underside of each nozzle in the photo.
Hope this helps.
