CraigsList alerts for Nissan/Datsun diesels
83 Nissan 4X4 SD-22 conversion Los Angeles. $3500
http://losangeles.craigslist.org/lac/ct ... 46002.html
i have a 1983 nissan pick up 4x4 has a diesel motor in it 5 speed with reverse trans runs good starts up fine was my project but due to limited time and space i cant have it anymore im asking 3500 obo to get it registered you will need a diesel verification all together with dmv fees will be around 450$ NO trades emails or texts contact at 323-974-3330
Charlie
Charlie
78 240D Mercedes $300 Parts?
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
86 Ford F250 6.9 Diesel 221K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
82 Datsun 720 SD-22 150K miles. $4500 Los Angeles
http://losangeles.craigslist.org/sfv/ct ... 85403.html
1982 Nissan Datsun 720 Pickup truck DIESEL - $4500 (North Hills)
Selling my 1982 Nissan Datsun 720 Diesel truck. It's an extended Cab.
Has 150,000 original miles. Comes with front grill guard, commercial 3 door work camper, and ladder rack. The body is in really good condition, has minimum surface rust on 2 areas, not cancerous rust though, no holes. Original paint, no dings, body is straight. Clean Title.
Seats are torn, 7/10 condition. I have some seat covers on them, they still hold up.
The truck is in great condition for it's age. Starts right up everytime, and it's very economic, gets 40-45 Miles per galon. You can come test drive it all you want, it's a really reliable truck, has no issues at all. You can drive it until you're sure that it works and that you're comfortable with how it works, the truck is in perfect running condition.
Has 85% thread left on Good year tires.
Manual Transmission, No Air conditioning, No power steering,
I'm asking $4,500 obo for it. This is a really Rare truck, especially for the condition this one is in. You don't see these diesel trucks around anymore, this is an original diesel, not a conversion.
If you're interested, give me a call or text me anytime at 1(818)332-6943 , I'm available to show it all day today (Sunday 08/25/2013), thanks! I will upload pictures by noon. Feel free to call if you have any questions.
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
Sd-22 engine used to power a boat. $900 S.F Bay Area
http://sfbay.craigslist.org/eby/pts/4025954678.html
54 hp diesel with transmission - $900 (richmond / point / annex)
strong running nissan diesel with transmission.
after motoring a 15 ton sailboat from 40 nautical miles, i pulled the engine, with transmission. i dont know how many hours are on the engine. i do know that the boat is a 1978 and it sat in the a marina for over 10 years without moving and i pulled the motor over 2 years ago.
motor starts every time and runs strong while holding it's idle right at 500 rpms.
transmission is tight and responsive.
while i was still planning on using this motor for the new boat, i was planning on replacing the hoses and repaint.
located in richmond ca.
instrument panel is included.
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
SD-22 720 King Cab Diesel engine, needs work.
http://portland.craigslist.org/mlt/cto/4027144471.html
1982 Nissan Diesel truck factory (se)
image 1image 2
truck is original diesel truck from new extra cab needs work if interested call (971) 570-2567
Charlie
image 1image 2
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
84 Datsun king cab Sd-25, been run on WVO. I wouldn`t touch this one.
http://spokane.craigslist.org/cto/4010666914.html
Its a kingcab 2wd 5 speed with the SD25 diesel. I normally get about 33MPG in town. I've also run veggie grease and used motor oil in it often. The truck has 222,xxx miles on it and is a little hard to start. Second try it fires up (probably needs glow plugs). Just put a new clutch in, carrier bearing, new lift pump, valve cover gasket, and the injectors were professionally rebuilt not long ago. Also comes with a brand new starter and has a glow bar installed in the intake to help with starting in cold weather. The truck recently developed a small knock and might be a rod, injection pump timing, valves?? Still starts and drives fine. The body is in great shape for the age, has a hole in the bed (as pictured). The interior is nice as well. It has a decent set of tires on it and a bumper hitch plus light kit for hauling a small trailer. This pickup has been reliable transportation for the last 3 years for me. Asking $1500 OBO Call, text, or email anytime. 509 five-five-7 five-9-six-three
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
83 king Cab 90k original miles $4995,....and it get 40 - 50 MPG on WVO. been breathing too many WVO fumes. ;>) NO way it see that mileage.
http://spokane.craigslist.org/cto/3944994534.html
Rare Diesel engine. Only 90,000 original miles. Perfect body, new tires, excellent interior, 5 speed, Trailer hitch, Brand new paint job, perfect bed. This is a winner. It is running on free restaurant fry oil and getting 40 - 50 mpg.
208-683-8026 What is it worth?
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
82 King Cab Sd-22 $1995
http://lewiston.craigslist.org/cto/3972994713.html
Great Transportation small pickup, only 111500 miles on 4 cl diesel engine. Very economical to run with good fuel economy. Truck has a 5 speed manual transmission, king cab for extra room, body is straight with no major dents or dings. Some clear coat failure on hood and roof, tires are good. This is just the truck you need for helping out around the property and getting you to your work or play without spending it all on fuel. Available for inspection and test drive, Just call Jack at 509-758-8274 •Location: Clarkston
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
http://sfbay.craigslist.org/nby/pts/4041948908.html
nissan diesel sd22 - $400 (petaluma)
Just picked up a 4 cylinder Nissan diesel engine don't know much about it. Just flushed the fuel system and cooling. Has clutch and pressure plate ready for a fork lift, truck or what ever you can think of
turns over so that's a plus. shoot me an offer Jared 7077767307 calls only please
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
1982 datsun diesel pickup manuel - $1000 (Petaluma
http://sfbay.craigslist.org/nby/cto/4149160397.html
Been sitting awhile so it could use a jump and a good cleaning but it did run well and get very good gas mileage. The plastic coolant tank could use replacing very cheap call john at 7078889240 1000 obo. Never put on non op about $700 in back fees might serve better as a parts truck depending on how much you want to invest in it.
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
http://sfbay.craigslist.org/eby/pts/4148703911.html
DATSUN V07 DIESEL MAXIMA ENGINE complete w/ Transmission - $1000 (fremont / union city / newark)
For Sale:
Datsun Diesel V07 Maxima motor with Automatic Trans.
Engine was pickled and stored in doors years ago, was out of a maxima that was totaled with 75K miles on it. I've been storing this for a long time because I was going to yank the crank out for a stroker project, but couldn't make myself tear apart a complete rare running diesel engine just for the crank...
This thing is a sure runner, and if you have a maxima or want to do a diesel swap in your vehicle, here ya go! 1,000$
As is , where is. Yes if this ad is up- it is still for sale, it is a complete drive train!
I have a engine hoist, so bring CASH and a truck!
Email with phone #
Charlie
For Sale:
Email with phone #
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
http://medford.craigslist.org/cto/4157497685.html
Nissan/Datsun Diesel 720 king cab 2wd 1981 - $4000 (eugene) Oregon
1981 Datsun/Nissan king cab DIESEL. This truck is in complete working order, a little scuffed up but its all there. only 106,000 miles 30mpg..A bunch of new stuff:
Brakes front and rear
HD shocks all around
left and right upper and lower ball joints
muffler and tail pipe
Bucket seats from '01 dodge neon
Tires in July
Clutch
Clutch Master Cylinder
Clutch Slave Cylinder
Two toppers
This truck is my daily driver. starts cold doesn't smoke. Must Sell! Moving in two weeks.
ate zero 2-three eight 0- three seven 7 for....
Moving this truck has to go!
asking asking $4000.00 or best offer. •
Charlie
Tires in July
Clutch
Two toppers
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
http://portland.craigslist.org/wsc/cto/4154324174.html
datsun 1982 diesel - $4200 (sherwood) Oregon
image 1image 2image 3
hi am selling my truck datsun diesel 1982 the truck are running good 40 miles for gallon is strong motor good tires i for sale as is is very economy truck 5speed manual tramission any cuestion please call or text me at 503 453 4946 thanks
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
http://seattle.craigslist.org/see/pts/4160516562.html
Nissan diesel LD28 NOS injection pump - $900 (Duvall)
I bought two of these NOS (new old stock: brand-new) several years ago. Nissan No. 16700-W3311, this used to be available from Nissan for $2741. This might be the last brand-new automotive spec. LD28 IP available in the USA. It is the correct pump assembly for 1982 Datsun Maxima diesel. It should fit to most all LD28s (marine included) with minor differences (such as the design of the CSD (Cold-Start Device: raised idle and advanced timing when cold)).
This is a brand-new injection pump, not a rebuilt. Price out having this type of injection pump rebuilt, and you'll see that this one's a steal.
Manion Way at 153rd Pl
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
http://seattle.craigslist.org/sno/cto/4156661394.html
1981 Datsun Diesel Pickup - $1800 (snohomish)
After many years of faithful service my family has finally outgrown our beloved 'Black Magic'.
We are therefore selling our 1981 Datsun King Cab 2x4 Diesel Pickup Truck. She has a naturally aspirated diesel engine that is still running strong. Starts super easy and doesn't smoke. 5 speed tranny + diesel = excellent fuel economy (35 mpg easy). She is a hard worker that has never let me down. Never.
New front tires. New Spare. New front brakes. Spare glow plugs that I have had for years. Pretty darn straight body. All rust has been mitigated. Bed liner. Lumber rack that is off truck and in pieces if interested. Seats four with seatbelts. 169,211 miles.
Heater doesn't work. Radio doesn't work. Seats shredded . At least two holes in floor big enough to eat golf balls or maybe a baseball. Mirror broken. Aftermarket ignition pirated in.
We love this truck but just bought a crew cab so she has got to go (although we have had our other truck for months and I haven't had the heart to sell Black Magic).
Asking $1800.
No Texts. No Time Wasters.
425-5O8-twenty seven 12
Charlie
Asking $1800.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
http://spokane.craigslist.org/cto/4104522477.html
Diesel, 83 Datsun/Nissan X Cab PU - $4995 (Silverwood)
cell 208-704-6639
40 to 50MPG??? really, must be breathing too much WVO smoke. :<))
Charlie
cell 208-704-6639
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
