If you want to see more, let me know or check out the post I made in user rigs.
Zarghareth wrote:So I was just looking through the later parts of the tread more carefully and I hadn't realized there was so much confusion about the fuel regulation system before my previous post. I believe I can give a good explanation of how the stock governor works and how to set it up to make it work with a turbo.
NOTE: I am referring to the BOSCH KIKI pump.
Basically, the way the joint diaphragm-mechanical governor on the SD22 in the 720 is: if you open the throttle, more air is allowed to bypass the venturi generator located in the throttle body, thus decreasing the vacuum being applied to the diaphragm on the IP and subsequently increasing the amount of fuel delivered to the engine. Because of this, it is essential that the hose from the TB go to the correct side of the diaphragm. The mechanical governor just keeps RPM stable.
The reason why this system is set up using vacuum and diaphragm mechanism is very important. It dampens the movement of the regulating mechanism inside of the pump which is very sensitive and must exist constantly in a dynamic state. This is achieved by the diaphragm's inherent elastic properties and the "loose" actuation of it by the vacuum supplied from the throttle body. "Loose" meaning not capable of overly violent changes or holding 100% static.
With all of this in mind one can see how important it is to set up the throttle body and associated plumbing correctly. The main reason for leaving the TB in its stock position is that it measures the velocity of air moving through the engine and therefore, indirectly, volume not pressure. With the installation of a turbo, the velocity of air moving into the engine is much greater and thereby the vacuum being applied to the regulatory diaphragm is much greater, that is if you install the TB pre-turbo. With the TB post turbo, the pressure of the air in the intake system negates this increase in vacuum while still producing the low vacuum required by the IP control mechanism. In addition, it detracts greatly from turbo spool rates to have such a significant restriction before the turbo.
If you simply leave the throttle body in its stock position with the hose from the throttle body connecting to the rearmost hose barb on the IP and the forward hose barb on the IP open to atmosphere, It should work great. At least it has for me.
If you actually read all of that I really hope that it helps!
larrynsr wrote:I have driven over 5000 miles in the past few months. Its been my daily driver since the installation. The sd25 is holding up very well. No problems... weird noises or oil consumption. Power is great! I am currently running 10psi boost. A front mount intercooler has been installed but I have yet to do the plumbing as it's too cold! I'm hoping to run 12psi or so after the intercooler is hooked up. On thanksgiving I drove 200 miles one way using 4.2 gal of diesel. That's about 47 mpg. I am happy.
https://www.youtube.com/watch?v=laQjoO3 ... ata_player
https://www.youtube.com/watch?v=t37TJeg ... ata_player
Thanks. I am running about 4 psi at 55 mph on level ground at speed. Egt at this speed is about 600 degrees. fuel was left alone. I have read that for maximum efficiency and lowest egt, the exhaust manifold pressure to intake manifold pressure should be at a 2:1 ratio. Ideally it should be at 1:1 but I don't think that would be possible with a single turbo like this. I would one day like to swap this turbo for a vgt turbo. This way I can adjust for turbo lag and exhaust back pressure (to control egt). Im still doing my homework now, but i have my eye on a vgt turbo from a late model vw TDI.waynosworld wrote:larrynsr wrote:I have driven over 5000 miles in the past few months. Its been my daily driver since the installation. The sd25 is holding up very well. No problems... weird noises or oil consumption. Power is great! I am currently running 10psi boost. A front mount intercooler has been installed but I have yet to do the plumbing as it's too cold! I'm hoping to run 12psi or so after the intercooler is hooked up. On thanksgiving I drove 200 miles one way using 4.2 gal of diesel. That's about 47 mpg. I am happy.
That is really good mileage Larry, what EGT are you at while just driving down the freeway?
What is the boost at just going down the freeway?
Did you lean it out making this trip?
Great job on this, I am happy I met you that day, I am happy I responded to the craigslist wanted ad.
Users browsing this forum: Bing [Bot] and 2 guests
