Sadly the SD Engine parts are becoming...NLA
I put an order in for some engine parts for my new 83 Nissan SD-25 Long Bed PU. Got it from the original owner, but as time went on, he didn`t keep on the maintenance as he should. So Iam catching up on deferred maintenance and or neglect and abuse. :>((
I came across this on line vendor that handles Nissan parts, and put in an order for a few things.
http://www.nissanpartszone.com/
Item Description Qty. Unit
Price Ext
Price
16548-29W00 INSUL AIR CLENR
[720 Pickup | 1983 | T | SD25 | LONG | CAL] 1 4.08 4.08
15239-V1700 GSKT OIL FILTER
Replaced by: 15239-10G00 1 3.12 3.12
21308-90003 HOSE WATER
Replaced by: 21308-10G10 1 9.99 9.99
21069-61500 HOSE WATER PUMP
Replaced by: B1069-61500 1 16.56 16.56
01555-00281 CLAMP-HOSE
Replaced by: 01555-01181 2 2.19 4.38
21074-37502 GASKET
[720 Pickup | 1983 | T | SD25 | LONG | CAL] 1 0.72 0.72
21014-31W00 GASKET-PUMP
[720 Pickup | 1983 | T | SD25 | LONG | CAL] 1 1.47 1.47
21200-76204 THERMOSTAT ASSY
Replaced by: 21200-58G05 1 14.54 14.54
21383-90009 CLAMP HOSE
[720 Pickup | 1983 | T | SD25 | LONG | CAL] 2 4.00 8.00
14665-V1701 OIL TUBE ASSY
Replaced by: 14665-V170A 1 56.09 56.09
01351-22104 GASKET
[720 Pickup | 1983 | T | SD25 | LONG | CAL] 1 0.66 0.66
Subtotal $119.61
Tax $11.36
Best Standard Delivery $13.01
Total $143.98
Get an E-Mail today that the following are NLA. No surprise.
15230-V1700 Gasket Oil Filter
21074-37502 Gasket
21014-31W00 Gasket Pump
14665-V1701 Oil Tube Assembly (Oil supply to vac pump)
21383-90009 Hose Clamp
16584-29W00 Insul Air Cleaner (Rubber piece between the air filter housing and the air intake Butter Fly Gizmo.)
Well at least the Bypass Hose and the Oil Cooler Coolant hose are still in stock. I have the originals on the engine. They are as hard as a old piece of Bakalite..
Still amazing some of these parts are still available after 30 years.
Some of these complete engine gasket kits I see on E-Bay, may have all the gaskets that are NLA from the Dealer network.
Last June I was pulling the SD-22 Engine/Trans out of the 82 King-Cab. Thought I had everything disconnected. Dumb Arse here forgot to disconnect the Throttle cable at the engine Buttery Fly Gizmo. well the cable got stretched. :>(
No problem, just order one. well another part that is NLA.
The one for a Gasser will work, though about twice as long.
The Rubber Boot on the floor the shift lever goes through is...NLA.
Found a new one in PNP. :>))
Don`t have the part #`s for these last two.
Charlie
Price Ext
Price
21074-37502 GASKET
01351-22104 GASKET
Subtotal $119.61
Tax $11.36
Total $143.98
21074-37502 Gasket
Charlie
78 240D Mercedes $300 Parts?
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
86 Ford F250 6.9 Diesel 221K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
Parts finally came in a couple days ago, a total of only four.
01351-22104 Gasket. (actually a Copper "O" Ring.)
21200-58G05 Thermostat. (Around $14, dealer price is about $28)
21308-10G10 Water Hose for Oil Cooler. (J Hose)
B1069-61500 Water Hose, By-pass Hose.
Checked with the Dealer and the guy said the hoses are NLA. Maybe I got the last two ;>))
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
you're not kidding about parts becoming tough to get! I am looking for a head gasket, Nissan does not have them, and cannot get them (at $119!!!).
Local parts stores cant get them, looking at entire motor gasket set, parts store(s) took my # and "will get back to me."
The Nissan dealer recommended I check with Helmar (forklift supply):
http://www.helmarparts.com
Briefly looking at their website, their prices are great but you need to know the part #, as well as know for certain that the forklift part is the same as the 720 sd22.
check with these guys, they have a engine gasket kit, and shows the head gasket.
http://www.nissanpartszone.com/Page_Pro ... entsNo=102
I did some more poking around and found the head gasket separately.
http://www.nissanpartszone.com/Page_Pro ... nlPartList
11044 GASKET-CYLINDER HEAD
Replaced by: 11044-V1702 11044-Y1401 1979.06-1981.12 SD22
$107.17
$80.89
Replaced by: 11044-09W01 11044-09W00 1982.11- SD25
$81.00
$61.14
Hope this helps.
Charlie
$107.17
$80.89
$81.00
$61.14
Hope this helps.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
Check this out, this is for a SD-25 engine. Don`t know what difference there is between these engines.
http://www.nissanpartszone.com/Page_Pro ... entsNo=111
Looks like you will have to click on engine mechanical on the left for the Head gasket.
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
