CraigsList alerts for Nissan/Datsun diesels
charmalu
#61
Post by charmalu »
Wow, $800 does seems sort of high. I haven`t shipped an engine so IDN on price. I would think maybe $200? I would think there would be a chart or Zone for shipping charges.
For $800, I could drive there in the old Datsun and make a nice trip out of it.
They definately have it written up in their favor.
Here is the details after I clicked on the link.
Description
Shipping and payments
Split the cost with friends
JDM Engines Corp
Seller assumes all responsibility for this listing.
Shipping and handling
Item location: Richardson, Texas, United States
Services available: Freight - Check the item description or contact the seller for details
Ships to: United States
Return policy
After receiving the item, contact seller within
Refund will be given as
Return shipping
14 days
Money back or item exchange (buyer's choice)
Buyer pays return shipping
Years ago there was an outfit named Atarco, they sold these engines for $600.00.
Charlie
78 240D Mercedes $300 Parts?
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
86 Ford F250 6.9 Diesel 221K
charmalu
#62
Post by charmalu »
http://www.ebay.com/itm/Nissan-SD-22-2- ... 67&vxp=mtr
Nissan SD 22 2.2 Liter Diesel Engine Long Block
This engine came out of a 1982 Datsun 720 pickup truck. Engine has been completely rebuilt. All the machine work was done by a professional machine shop. All cylinder liners have been replaced, new pistons, piston rings, rod bearings, main bearings, crankshaft polished, cylinder head rebuilt, and the injectors were sent to pump shop and completely rebuilt. As you know the machine work and parts alone are more than I am asking but I no longer need. The engine has been sitting inside my building and does not look like I will ever need. Please email any further questions. Thanks.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#63
Post by charmalu »
http://seattle.craigslist.org/see/cto/4253192964.html
82 Datsun extended cab diesel pickup 2whl dr. - $2200 (Port Townsend)
82 datsun pickup 256,000 miles runs and drives good. Smokes on startup, but not after warmed up. sd22 diesel motor and 5 speed manual transmission. Fuel guage doesn't work, but everything else does. I would guess 40-45 mpg. Nice interior for this old girl. possible veggie oil conversion. Give me a call to take a look and test drive. 360-316-0988
Note:
This one looks like mine, red with black interior, but no camper.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#64
Post by charmalu »
http://seattle.craigslist.org/tac/pts/4248619536.html
SD22 Nissan diesel with trans and case - $750 (Lacey)
Running sd22 4cylinder diesel with 2wd trans attached and driveline. I bought an X-terra Tcase for 4x4 conversation needs a 4x4 trans. This would make a killer 50mpg set up, just don't have funds to finish the job. make a reasonable offer for all 928-581-3929
50MPG??? In his dreams.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#65
Post by charmalu »
http://lasvegas.craigslist.org/ptd/4251824582.html
DATSUN PICKUP NISSAN SD22 DIESEL ENGINE AND ACCESSORIES - $450 (las vegas)
the price on this item may have dropped even lower than listed here. visit the link below for this huge deal!
copy and paste the link below to your browser.
http://www.bigsalesavings.com/auto-parts_209328.html
datsun pickup nissan sd22 diesel engine and accessories
other devices, clutch shoe, foglamp, door control module, generator, wheel stud, shift improver, piston, glass, cruise control computer, pitman arm, anti-lock braking system abs, pcv valve positive crankcase ventilation valve, temperature sensor, armrest, turbocharger and supercharger, camshaft position sensor, brake servo, hinge, temperature sensor, brake pad, strut, thermostat, armrest, center console front and rear, window seal, fan belt, door seal, idler arm, seat belt, starter drive, switches, brake line, electronic timing controller, engine sensor, pressure sensor, door switch, door watershield, engine block parts, ignition coil.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#66
Post by charmalu »
http://kpr.craigslist.org/cto/4251856100.html
87 Mazda pickup (diesel) 46mpg - $2200 (Tri)
87 mAzda b2200
2wd
5speed
Nissan Diesel motor swap
Text or call for more info
15094403657
Looks like a Nissan SD-22 Diesel engine swapped into the Mazda.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#67
Post by charmalu »
This is most likely a SD-22 engine
http://corvallis.craigslist.org/cto/4229061461.html
diesel datsun with 2.2l 2wd good for parts or fix - $750 (valley)
1982 datsun diesel
82 datsun factory diesel 2wd with canopy body rough but not rotted out,not sure whats wrong was told glow system wasnt working, has 5-spd5412076673 5417529454
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#68
Post by charmalu »
http://oregoncoast.craigslist.org/pts/4249549356.html
Nissan diesel motor. - $2000 (bandon )
I have a Nissan diesel motor it was running a water pump runs good has a new water pump $2000 obo for pictures and more info call or text jake at 541 551 0138.
Wonder what engine???
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
rustie
Post by rustie »
charmalu.....awesome job on posting all these available engines!
Still like to find a near new SD25 sometime. Probably dreaming though....
charmalu
#70
Post by charmalu »
You are welcome.
Some times I can`t one of them, then all of a sudden they seem to be falling out of the sky.
Some of these people have just plain junk that they think is Gold Plated.
Just be aware, most of these are old rusty vehicles, with abused and neglected engines. Most will not be plug and play, drop it in and drive away.
I have been going through this 83 SD-25 with 136K from the orig owner. so far a new Clutch, couple Bearings in the Trans, new Water Pump, Thermostat, Bypass Hose, Oil Cooler Hose, replaced corroded Thermostat housing with a good used one.
Cleaned up the Radiator, and a good portion of the Fins crumbled. probab ly from being close to the ocean sea air. So looking for one of these now,but the Diesel Radiators are NLA, have to go with a gasser one. maybe I can have the top/bottom tanks swapped over to the gasser.
A SD-25 will show up for you when you are not looking for it. :>)
Check with http://www.row52.com put in what you are looking for and they will notify you when it shows up. will show a picture and the VIN #.
Look in http://www.picknpull.com too, for what you are looking for, but the row52 cars will be one`s that are in the PNP yards.
Happy New Year.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#71
Post by charmalu »
LD-28 Nissan Diesel engine in a 92 Toyota 4X4.
http://bakersfield.craigslist.org/cto/4251487656.html
92 Toyota 4x4 Diesel Extended cab - $4750 (Tehachapi)
With Fuel prices reaching towards all time high's, here is your chance to own a 1992 Toyota Extended cab 4x4 DIESEL pickup. Runs great. Manual transmission. 5spd. This truck is a deluxe not Tacoma model. This truck has the Nissan RD 28 Diesel motor installed. Its a 6 cylinder. series 2 Motor is very clean. No leaks. Remainder of running gear appears to be stock Toyota. Who ever did the conversion did a pretty decent job. The truck has been used quite awhile since conversion. It has 198,817 miles on the odometer. 4x4 works as it should. Fuel gauge works also. Odometer is broke at this time. The truck belonged to my son who does not need it any longer. He got a bigger truck.
The truck is Legally registered in the beautiful state of California as a DIESEL.. And its current. That means no more smog inspections.. For those of you who have dealt with the DMV in such a matter, you know The asking price is worth the effort getting it registered. HAHA.
The body is in overall good shape. There was a little rust on the front fenders, That is why he changed them out. The interior is not bad also. The door panels have holes where speakers were removed.. Tires are about 30% percent. Roll up windows and manual locks.
This would be a good little work truck. Gets good mileage. Runs good. If your looking for something perfect, this is not it. Its 21 years old.
There is a little short in the truck. Battery goes very low after sitting a week or so without attention.
If you have any questions feel free to call.
Always open to interesting trades. Nothing i have to feed though. haha.
SIX SIX ONE 972 SIX 0 SIX 0
Thanks
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#72
Post by charmalu »
82 Datsun SD-22, this thing is really beat up looking. Just pictures of the truck, no engine pic. way over priced for this Gold plated rust bucket.
220K miles
http://losangeles.craigslist.org/lac/ct ... 36143.html
1982 Datsun King Cab Pick-Up Diesel - $2500 (Rialto CA)
$2500
1982 Datsun king cab pick up
Diesel
For more info pls call or text
Rialto is in San Bernardino County
Se habla espanol
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#73
Post by charmalu »
83 Nissan 4X4 Diesel conversion not finished, or DMV paper work.
http://losangeles.craigslist.org/lac/ct ... 01721.html
1983 Nissan Pick Up Diesel conversion 4x4 - $3500 (Los Angeles)
i have a 1983 nissan pick up 4x4 has a diesel motor in it 5 speed with reverse trans runs good starts up fine was my project but due to limited time and space i cant have it anymore im asking 3500 obo to get it registered you will need a diesel verification all together with dmv fees will be around 450$ NO trades emails or texts contact at (323)420-5894 Manuel
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#74
Post by charmalu »
This is a really clean looking Cornbinder. this is one of the last one`s they built. looks like the Nissan SD-33 NA.
Has the blue calif plate, so originally sold in calif.
http://modesto.craigslist.org/cto/4209316255.html
1979 International Pickup - $7500 (Modesto)
1979 International Pickup: 1/2 ton pickup with Nissan diesel engine, 6 cylinder, manual transmission/ 4 speed with 4 wheel drive. has new tires runs well. 70,000 miles on the odometer. kept in shed, owner ready to sell.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
charmalu
#75
Post by charmalu »
Iam only posting this because it does have a Nissan Diesel engine, though a 7 leter. the perfect vehicle to go pick up these rusty old 720 Diesels we drag home. :>)) Dang iam always a couple $$$ short when something good comes along. :>/
http://modesto.craigslist.org/cto/4254287006.html
Custom Built 3/4 Scale Peterbilt Truck - $25000 (Modesto
My father built this one-off truck in the mid 90's. It is hand built by an expert metal worker. I can guarantee you will not find another one like it.
This vehicle looks like a Peterbilt truck but is in fact only 70 or 80 percent the size of one. It is registered as a home-made pick-up truck not as a semi-trailer truck. It is powered by a 7 liter Nissan diesel engine. My father died 90% through making this vehicle and so it has very low miles on it as he only drove it around in Nevada for a year or so. It could use some paint and the interior needs to be finished. It has a manual gearbox. This truck is "air-ride" equipped.
This truck runs and is in working mechanical order. The starter motor was just rebuilt and a new slave cylinder installed.
I am selling this truck because I do not have the resources to finish it. It has been in my family for two decades and I feel a great sorrow knowing it has become an family relic resigned to sitting around getting dusty when it should be out on the road getting strange looks and big smiles from truckers.
If you have any questions - feel free to send an e-mail. Name is David.
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
