thought also occurs... what about actually using an impco mixer and the vapourizer? instead of just the vapourizer. the factory mixers are adjustable like a carb. maybe run one pre turbo with a secondary flange mounted on?
ehtrain wrote:very interesting stuff given propane is 120ish OCTANE and diesel is CETANE(the opposite on the scale). Amazing how LPG works in a dieselIf I can get my engine to stay running...cough..cough... ill look at propane for sure. Ever since I was young kid interested in vehicles and watched stacey david from "trucks" put a propane system on a ford I think it was. I've always thought about doing it. I tried doing some research before I turbo'd and info seemed very hit and miss. I found a few systems that used nitrous and propane. I like the idea but thats getting pretty intense for parts and expensive failures if anything happens without all the knowledge required for setup and maintenance..etc...etc... the VE injection pump would seem well suited for this type of testing given it doesnt need a throttle blade..... hmmm maybe thats a good spot for fogger nozzle after the throttle shaft is removed....
elminero67 wrote:I'm curious as to how well that contraption worked and how long it lasted?
elminero67 wrote:that's what I was looking at-the welded up exhaust manifold with at least one of the cylinders flowing backwards against the direction it was intended. I imagine it did not optimize performance, but also wonder if the uneven backpressure would lead to head gasket failure-or worse.
I know you keep mentioning that you believe that too big of a turbo is one of the issues, and I struggle trying to understand that concept: In my mind, you are confusing volume with pressure. It may have a slightly slower windup if it is too big (the one I will be using is for a 2400cc gas motor vs the 2300cc diesel), but I don't understand how you feel that is what is leading to the failures we have seen with turbos on the SD series motors.
Not trying to be argumentative, just trying to understand before installing on my new SD23.
ehtrain wrote:elminero67 wrote:that's what I was looking at-the welded up exhaust manifold with at least one of the cylinders flowing backwards against the direction it was intended. I imagine it did not optimize performance, but also wonder if the uneven backpressure would lead to head gasket failure-or worse.
I can possibly shed some light on your questions, and some of it has already been answered in above post. in terms of manifold "flow" yes 1 cylinder would have poor flow as it would have bends this would slow down the velocity of the exhaust from that cylinder and would also reduce the amount of exhaust that can flow and be scavaged out. if you were to put and egt gauge on each cylinder as with any manifold with unequal length runners you will see performance difference in each cylinder in terms of temp and volumetric efficiency. Thats the reason why performance manifolds are equal length runners. this corrects the flow across to the same level on all cylinders trying improve the power the most and create the most scavaging effect between exhaust pulses (yes exhaust comes out in small pulses not a stream) this is why I created a "J" pipe for my turbo as this helps the manifold flow the most like stock while not creating sharp bends or incorrect flow patterns.
ok and to answer your question on turbo gas vs diesel. It's all about volumetric efficiency. gas engines are not very efficient and require the fuel and the incoming air to be metered. energy can't be destroyed it can only be transformed. gas turns about 60-70% of its energy into coolant heat and unburnt fuel. the other 30% is used to move your vehicle. Add a turbo - more air means more fuel means more power. however do to this inefficiency there are larger exhaust volumes. so a turbo needs a larger turbine to handle the output as well as the input air. gas also has a larger rpm range to play with requiring a turbo with a larger capacity.
diesel turns roughly 40% of its energy into waist like coolant heat and exhaust heat. meaning approx. 60% of the fuels energy is used to move the vehicle. this is why diesel is generally a more efficient motor. it comes down to how it works and fuel it uses. and diesel does not need a throttle blade like a gas. so the turbo has a physically larger area to cover over the gas as it has to maintain pressure against the intake valves at all speeds. where a gas engine will not build boost until the throttle is opened allowing more flow. so because diesel has a slightly increased air demand and decreased exhaust volume the turbo needs a smaller exhaust turbine to make up for flow speed. this is why diesel projects like mine suffer "turbo lag" from an over sized exhaust turbine. diesel also redlines around 4-4500rpm on IDI engines. so your rpms range is very limited in comparision to say 6-9000 for gas. thats generally why you see a diesel turbo with tiny exhaust turbine and larger compressor. a good model of this here locally is if you own a diesel at -30c it idles all day unless your plugged in. even then you might have to idle up to 1700rpm or so to keep the engine warm enough it wont carbon up or let the oil cool down to much making for hard re-start. lots of us switch to thinner oils to reduce the friction and effort it takes to pump cold oil on start up. diesel is efficient enough the engine could be hot when you park it and let it idle for 20 min and come out to see the temp gauge on cold again unless its idled up. a gas engine let it idle for 20min at -30c your temp gauge will go from cold to hot and stay there. it expels more heat in inefficiency then a diesel by significant amounts.
to be honest to the arguement compression is the biggest thing that changes efficiency. gas can get more efficient but you need higher octane fuels (more stable burn). when I was doing the math of flow i found a 1.8L turbo gas motor (ca18det) has similar flow requirments for the sd25 diesel. the gas motor would make probably 225-230hp while the diesel would top out at 150ish if that was possible. there are compressor and turbine maps that combine flow and turbine speeds so you are able to choose the turbo for your application assuming you want to do the math. Garrett turbo's website has a long tech page on turbos and explaining the various aspects. If I recall right gas exhaust speed is high volume but low speed. but a diesel is high speed and low volume. I had a book somewhere explaining all this... by tom grilles i believe it was.
