Has a 4.375 rear gear with 225/50R15 tires. 75mph should be around 3000RPMS, if it has the power to get that fast. I've only driven it around the block.
http://youtu.be/wukJctT-VcM?list=UUdAkk ... klCN02yMBw[/youtube]
waynosworld wrote:Your going to be lucky to get 60mph out of 437 gears, I was getting 70mph at 3000rpms using 390 gears(stock) on level ground or down hill using stock size tires.
Right now I have a 521KC with an SD25, I can go 80mph at 3000rpms, I am running 350 gears.
If I were you, I would be looking for 390 gears to put in your rearend, you might be able to use the 370 gears in the 620, but that is pushing it for a SD22, after all, they only have 61hp.
As for turbocharging it, forget it with the inline injection pump, I have a turbocharged SD25 with an inline injection pump, and a lot of time was put into this setup, but it is a fail, the vacuum controlled inline injection pump rack is just not made for a turbocharger, mine runs, but it gets very hot fast on the hiway, I cannot go 70mph and keep the EGTs below 1400 degrees, around town it is fine, but my SD25 without the turbo is fine around town, I want power on the hiway, so it is a fail.
ehtrain wrote:very interesting! There still should be a way to manually control the fuel rack without that diaphram and a bunch of contraption. I don't have this style IP currently on a running engine so I have done very little research other then general operation. My truck has the VE IP and It seems to run very nicely. I am continued to be impressed the more i play with it. The only time I experienced this "power drop off" or slowing down on highway when you max throttle. Was stock non turbo fuel level with 2-10psi. However now that I have started doing fuel adjustments it seems to have really woke up the truck. I seem to be getting as good or better mileage and now it has reasonable highway power and my egt's seem to be basicly the same at peak loads.
im almost positive an early td27t injection pump (pre-94 I think? has mechanical timing VE IP) will bolt in the VE injection pump plate on the sd25/sd23. This is what I have been thinking about swapping as the turbo aneroid prevents max fuel until boost, is how I understand it works. Which would be good as I think the more I crank the fuel screw in on my standard VE pump my idle rpms and fuel will increase... and possibly black smoke at idle? I have yet to find out as the truck is still pretty shy with the black smoke.
sorry for the thread hijack haha
ehtrain wrote:I was cruising jeep cj10 forums looking for info on belhousing swaps. this guy has comething like what I imagine http://www.pirate4x4.com/forum/jeep-har ... ild-3.html
I really dont think this s^&% is that complex. I may fiddle with a inline IP if my engine keeps running strong. I have no doubts that there is an easy solution to all this confusion.
heres a bunch of cj10a links. lots still have sd33 check out some builds http://www.pirate4x4.com/forum/jeep-har ... hread.html
