Hi,
I am looking for a good LD28 block (block with main caps only is fine)... near Martinsville, VA if possible. However, if it needs to be shipped via freight, that is fine. Thanks in advance!
Garrett
Need LD28 block - willing to pay for shipping
Re: Need LD28 block - willing to pay for shipping
I know members of ND forums have a unique distaste for 'crank pirates', but considering you only need the block, why not post on some of the Z forums..?
I know I've spoken with a half a dozen people who have LD parts, minus cranks, in the past month or two. Unfortunately, none had the oil pan I'm looking for, but plenty had the block/ancillaries.
Hybridz (I know, I know), Datsun Parts and Needs on FB both have these floating around.
LanceVance wrote:I know members of ND forums have a unique distaste for 'crank pirates', but considering you only need the block, why not post on some of the Z forums..?
Hi LanceVance,
I actually posted on HybridZ first about a week or so ago:
http://forums.hybridz.org/topic/123938- ... ose-to-va/
I've had no response as of yet.
I have a 240z and plan to make a 3.5 L beast out of the block (custom machining and custom liners). I don't need the stock crank as I will be using a custom made billet crank with 90 mm stroke. Anyway, I respect that diesel folks have preferences... That said, if anyone has a block that otherwise would be sitting around without a use and wouldn't mind having it turned into an 8000 rpm z car transplant, then I'd be very grateful.
Garrett
LanceVance wrote: Datsun Parts and Needs on FB both have these floating around.
By the way, what are these? I can't find either online. If "Datsun Parts" is a website with a hyphen in it, then I know what that is. "Needs on FB" is probably Needs on Facebook, but I searched for that and can't find anything that looks like it would help track down a LD28 block. Thanks in advance.
G
Sorry for the late reply, haven't been able to get onto ND forums for the past few days?
Datsun Parts and Needs is a 'Group' on Facebook. It requires the Groups app and probably the Facebook messenger app as well. I'm not the most well versed in it's use as I've only just joined myself.
I have a bare block with caps if you still need one. $150 plus shipping. I'm in Colorado.
Duane
