TD starter on SD
Knugcab
TD starter on SD
Post by Knugcab »
I broke the starter on my 720 SD25, and found a starter from a D21 TD27 for sale, will it fit?
Re: TD starter on SD
Post by Nissan_Ranger »
If they look the same, why not try it and see...?
Knugcab
Post by Knugcab »
Because it is easier to ask if someone already know the answer instead of going to see an unknown starter. :mrgreen:
However, I found a SD starter in the junkyard so I solved the problem that way.
ehtrain
Post by ehtrain »
The starter is on the opposite side even if did fit the belhousing hole which I believe my td27 has a slightly larger starter. The starter housing is clocked to the other side. So upon install I believe the starter will contact the block if it fits at all. I'll double check as I have all 3 types of starter. Both the sd25 and the td27.
Knugcab
Post by Knugcab »
I replaced the starter with another SD starter, but now I need a flywheel, SD engines are somewhat rare in Sweden nowadays, I found that a junkyard in southern sweden (many miles away) had a 1987 D21 SD25 flywheel for sale, can I use that one on my 1985 720?
Knugcab wrote:I replaced the starter with another SD starter, but now I need a flywheel, SD engines are somewhat rare in Sweden nowadays, I found that a junkyard in southern sweden (many miles away) had a 1987 D21 SD25 flywheel for sale, can I use that one on my 1985 720?
I believe that all SD25 flywheels are the same and will interchange, the SD22 flywheel will not work, at least the 3 main bearing cranks will not as they have a different bolt pattern, but the ring gear itself on the SD22 flywheel is the same as the SD25 ring gear, as they all use the same starter(SD22/SD25).
Knugcab
Post by Knugcab »
Sigh, I didn't get that flywheel....
And SD engines seems to get rare in Sweden.... No luck in finding a new one...
I guess a TD flywheel won't fit? :(
Knugcab wrote:Sigh, I didn't get that flywheel....
So now you need to figure out if the ring gear itself is actually loose on the flywheel, if it is I would first see if it has a crack somewhere, if not I would tack weld it in position in at least 4 different places, but that is me.
I have never heard of one slipping before, may I suggest marking the ring gear/flywheel and try the starter again and check to see if the ring gear is actually moving on the flywheel.
Is the starter just spinning freely without engaging the flywheel/ring gear, or can you hear it actually grinding?
Knugcab
Post by Knugcab »
Well, there is more problems than the starter gear, a slipping clutch have lead to the surface being polished smooth, and it has blue spots and cracks from the heat, so it doesn't feel safe to use... :?
Knugcab wrote:Well, there is more problems than the starter gear, a slipping clutch have lead to the surface being polished smooth, and it has blue spots and cracks from the heat, so it doesn't feel safe to use... :?
The SD25 engines are kinda rare here also, I had to have one made from a napZ engine, and I had a SD22 ring gear put on that flywheel, it's all I could do.
I would have your flywheel resurfaced/turned, and have the ring gear checked, you are likely going to have to work with what you have.
Knugcab
Post by Knugcab »
I might have sourced a flywheel in Finland from a 1987 Urvan with SD23....I guess that will probably work. Waiting to get mail back from that junkyard....
