My WVO conversion & cooling system mods
after oil
Post by after oil »
In case youre interested:
on the right you'll see where i teed off from the heater hoses, on the left the heat exchanger w/ valve solenoid on top.
On the left you see the veggie oil filter with 1/4" coolant line wrapped around and taped w/ metal tape
Click on those, that was the best i could figure out for how to see these photos w/ imageshack
Zoltan
Post by Zoltan »
the pix are too small to see the details. Load them up to imageshack (it's free) and pick the size for message boards.
- Zoltan -
'86 Ford Escort 2.0L Diesel
Zoltan wrote:the pix are too small to see the details. Load them up to imageshack (it's free) and pick the size for message boards.
I copied both to Photoshop and resized to 800x600. The photos tell little about coolant hose routing.
From what little I can see, coolant flow is backward which would promote air locks.
The thing here is the use of WVO in a rotary injection pump.
Oh waitress ... Check Please.
after oil
Post by after oil »
i dont think the coolant flow is backward. we checked pretty thoroughly when we installed it.
after oil wrote:i dont think the coolant flow is backward. we checked pretty thoroughly when we installed it.
Concept: View each device filled with fluid but for about 10% air. Now position the device so that air bubble reaches a port. That port much be the EXIT point (the "high" point in the device). Never push down from the top to exit at the bottom as this promotes air locks.
Coolant LEAVES the thermostat elbow fitting. Plumb accordingly. And remember ... plumbed as a parallel circuit to the passenger compartment heater, anytime you command heat to the passenger compartment you will reduce coolant flow to your fuel heating devices at a time when they need it most.
Your new sigline ... it fits! :wink:
after oil
Post by after oil »
phillip, where would you plumb into for a system like mine?
after oil wrote:phillip, where would you plumb into for a system like mine?
How did I post a generic answer before you posed your question?
Seriously, I'd have to know more particulars about the devices. And even then, theory must give way to experience. For instance, it might be found necessary to use the U-shaped bypass to run your heat devices instead of tapping the heater circuit.
REDNECK
Post by REDNECK »
althought very curious about this oil thing, the obvious thing, to me, is the removal of the second battery this truck should have in the location of this stuff........and it's bearing on the electrical system.....but cool stuff man, very cool.........why the suprise with the rotory pump?......with all the stuff that happens in a in line pump, a rotoryhas alot less going on inside....to my knowlage.......I have rebuild alot of caterpillar inline injection pumps off the A,B, and C model motors......and with getting the segments right on the rack and timing them and adjusting the levels....I have fond them to be harder to rebuild than these tractor pumps?.....am I missing somthing so plainly obvious that i cannot see it.........and I am asking humbly....not as a smart@$$
87 D21,SD25.
may she NEVER stop smokin!
after oil
Post by after oil »
phillip replied
i see how it appears i got it plumbed backwards, but the heater hoses appear not as they are. i checked and everything is plumbed in the right order(bottom to top).
now, what if i send coolant first to the WVO stuff, then to the heater... ie inline rather than in parallel?
thats the way it came to me. all the mechanics i asked agreed that if its starting fine i dont need a second battery.
i have gone through a few starter clutches though...
REDNECK
Post by REDNECK »
I have always kept the two battery's in there in the case that the fuel filter waxes up and it's cold out and have to prime the system, the little pump on the top of the fuel filter housing is a pain if forced to put new fuel in the system on cold day.............
87 D21,SD25.
after oil
Post by after oil »
you: alberta...COLD= two batteries
me: sunshine coast, BC... one battery will do :wink:
after oil
Post by after oil »
BUMP
my earlier query:
anybody have an opinion or two on this?
