man oh man... i broke my "tube fuel spill" part # 16671 09w2
i call it fuel return from injector line. its 4 rings connected by a very small diameter pipe. nissan only has them in japan.
can anybody help?
tube fuel spill wanted
after oil
after oil
Yeah, I got a spare off a JY SD22, then two days later bought an SD with one broken.
"Low pressure" in this context means up to around 20 PSI on the return loop, according to Philip.
Member the-486 found a fix for just that problem, without having to have the Nissan line assy.
Personally, I'd attempt to braze it, but brazing tubing can be tricky unless you do it all the time. A professional can do it, certainly.
after oil
repaired
