which is the o-ring?
That's rather odd looking. I hope that's a pic before the head work was performed; those valves do not look very well cleaned up.after oil wrote:the crack . . . look between the valve seats.
I'm kind of burned out on the topic -- I've said my piece. If it's mated to very clean surfaces that are flat, I would re-use it, since the engine was not run and it is not a gasket that is compressed appreciably in service, and you are reusing it on exactly the same surfaces the second time.and still no discussion regarding the re-use of steel head gasket?
no, thats after. the head is wet with wd-40 or somethingThat's rather odd looking. I hope that's a pic before the head work was performed; those valves do not look very well cleaned up.
sorry... al, your the only person to comment on the fact that my gasket is steel. so i was hoping once that came to light the others might have a different perspective.I'm kind of burned out on the topic -- I've said my piece. If it's mated to very clean surfaces that are flat, I would re-use it, since the engine was not run and it is not a gasket that is compressed appreciably in service, and you are reusing it on exactly the same surfaces the second time.
"After Oil": Would you please tell: Was the critical, smallest, crack do to the head gasket between coolant and cylinder? (not refering to block or head).after oil wrote:SNIP- I know a guy who has had his 1987 D21 SD25 parked for years becuase he didnt have time to deal with it. he finally got a mechanic to tell him what was wrong: blown head gasket-SNIP- I thank you all, posters and lurkers, for accompaning me through this whole loony process, especially our respected forum moderator philip!!
glad to hear it's running and hopefully running ok!after oil wrote: i drove around the neighbourhood for a little while today and i think everything is A-OK!!!!
Now that's a great deal....relish this, they don't come up often enough!after oil wrote:and the universe rewarded me today for my perserverence:
i know a guy who has had his 1987 D21 SD25 parked for years becuase he didnt have time to deal with it. he finally got a mechanic to tell him what was wrong: blown head gasket![]()
he phoned me this morning and GAVE me his truck for FREE
Users browsing this forum: Google [Bot] and 3 guests
