SD33 to pickup swap
SD33 to pickup swap
hi, im sure this has been talked about before but I was wondering how possible it would be to swap an sd 33 into an 87 nissan pickup.I really would like a diesel that was comparable to the v6 gas engine in power. if this wouldnt work does anyone know of an engine that mght work? Tim
A '78 Wagoneer was designed to accommodate a straight Six; the '87 Nissan D21 was not!
My point was, If he enuff time and tools he can make it happend. You can cut from the wall in the engine bay. then you have to move the motor, and the gerabox a little bit back. this way the engine will be a little bit in the cars cab, and you might have to chance the dashboard. this was done to Land Rover Defnder, when they put 5,9 cummins in him.asavage wrote:A '78 Wagoneer was designed to accommodate a straight Six; the '87 Nissan D21 was not!
