Or just replace the relay every few years
Aha!philip wrote:2) Should the engine die for any reason, the DPC automatically moves the Fuel Control Lever to the OFF position. This prevents the engine from actually firing off and running in reverse rotation (ie, rolling backward in gear/clutch engaged).
Wasn't that some Australian fella? He rolled the truck on its roof (didn't kill the engine) and the closed crankcase breather system fed enough oil into the intake manifold to keep the engine running fast ... even after he cut OFF the ignition switch? Running just on the lube oil.asavage wrote:Another fellow rolled his rig and couldn't turn it off! It seems the crankcase oil somehow got vented to the air filter, and the engine was running on the lube oil.
Yeeeesssss . . . but then you may as well go to a cable, which is the simplest control system. The beauty of the DPC system, with all its complexity, is the various modes and situations it handles. Such as engine shutdown if oil pressure drops.dieselscout80 wrote:Could the electric motor that opterates the pump be setup to run manually with switches?
Yup.... I just remembered that I put a loose vacum tube back onto the vacuum amplifier (attached to the firewall and looks like a land mine) just before we started to work on the transmission. It seems that this was detached on purpose by the previous owner. This tube goes into the EGR valve system. If I put this vacuum tube back, the idle goes up and it overfuels the engine. I'll continue my trouble shooting on the EGR thread. Thanks for all the help.Zoltan, if your engine has EGR and the valve opens at idle, Philip says that the idle will increase.
Also, remember that venturi vacuum is what is pulling the IP's diaphragm to the idle position. If you have a leak on that line anywhere between the throttle body and the IP's diaphragm housing, it'll overfuel.
I was kinda wondering if it could be done. When I got my Tug SD33 that has the MZ govnenor to install in my Scout I got the electric motor that controls the pump, but not the DPC. I've been controlling it with a cable, but I have wondered about how to use the motor.asavage wrote:Yeeeesssss . . . but then you may as well go to a cable, which is the simplest control system. The beauty of the DPC system, with all its complexity, is the various modes and situations it handles. Such as engine shutdown if oil pressure drops.dieselscout80 wrote:Could the electric motor that opterates the pump be setup to run manually with switches?
Are you handy with electrics? Can you read a wiring diagram? It can be done, but you'll need to be patient.dieselscout80 wrote:When I got my Tug SD33 that has the MZ govnenor to install in my Scout I got the electric motor that controls the pump, but not the DPC. I've been controlling it with a cable, but I have wondered about how to use the motor.
THANK YOU!!!!!!!!!asavage wrote:I've chopped this page from the FSM to make this a bit clearer (click on image for larger)
I've been having an infrequent problem with starting the engine. I rechecked the DPC and IPC electrical plugs. Key ignition stuff too. All the fuses. Even the blow-off fuses.asavage wrote:If you do this, do let me know how well it works, and if there is any downside.
The Mercedes Benz used a substantially similar inline IP (the same basic design that was licensed to Kiki-Diesel for use in Nissans) and the MB does not, TTBOMK, have an overfuel/Start mechanism.Zoltan wrote:Just got my truck a few weeks ago and the previous owner bypassed the start key with a glow-plug/ignition-on switch and a push-start button. Ergo the IP lever NEVER goes to the START position 1.
