Battery Issue
#16
There are lots of batteries out there that still have 12 - 13 V in them but no capacity to deliver any amperage. A voltage tester will tell you if your charging system is working and delivering voltage ( and hopefully amperage at the same time ) to the battery when the vehicle is running. A load test of the battery will eliminate a lot of the guess work.
P
Dairy
#17
Post by Dairy »
There is a draw coming from the battery. I disconnected the stereo, removed the alternator, and turned the fuse box switch under the dash to off. There is still a draw. Any help?
82 maxima ld28 200K
#18
Start pulling fuses, see when it stops.
Normally, I'd blame the alternator . . .
Disconnect the two fusible links at the positive battery terminal. Still > 20ma draw? Disconnect the fuses as Rufus suggested. Then the IPC module on the left fenderwell. Gotta be one of those.
Dairy
#20
Post by Dairy »
I talked to a shop and they said try the module on the fender first. The new alternator should be coming in today so ill start trying.
82 maxima ld28 200K
Dairy
#21
Post by Dairy »
So im still waiting on the alternator because they messed up the address. :evil: I pulled every fuse except the engine control. The only things I left connected was the fusible links and the battery alt. in the module. There is still a draw and im getting worried.
82 maxima ld28 200K
Any new news on this?
Dairy
#23
Post by Dairy »
Figured it out. Turns out the ac switch got turned on but my car has a aftermarket toggle switch for it so the pump was constatly engaged.
82 maxima ld28 200K
