* Brakes *
Philip-
I think that the shoes on my truck are all of equal length. I carefully examined them before installation to make sure that there were no differences. I also just went and checked the shoes that I removed. All four are identical. So, it seems that I will experience somewhat faster wear of the secondary shoes. This seems like it's not something to worry about. Correct?
Byron
82 Datsun 720 KC SD22
MPG Machine
MPG Machine
Oops ...moose60 wrote:Philip-
The system I described earlier is the brake design with a FLOATING self adjusting slack adjuster which is associated with the larger floating front caliper system starting in 1983.
But you have an '82 with the fixed (stationary) NON automatic slack adjuster and twin piston fixed front caliper.
With the fixed (to the backing plate) manual slack adjuster design, the shoe lining will be of equal length.
Philip wrote: You have a 1982 which is the last year of the FIXED (stationary) slack adjuster
I'm seeking clarification here:
My adjuster can slide on the backing plate. This is a sliding system different from the one I saw at the JY over the weekend (on newer trucks) which has the slack adjuster and the e-brake rod combined. The later system slack-adjusters also seem to be at the top of the backing plate, where mine is at the bottom.
Can my system be considered "fixed" due to the small amount of movement?
Byron
MPG Machine
MPG Machine
Image added to post Which way to rotate the star wheel adjuster
- Has thanked: 3 times
I'm guessing maybe this is the type of adjuster you have (eBay Auction 320063086056, BIN $18 ea)?moose60 wrote:I'm seeking clarification here:Philip wrote: You have a 1982 which is the last year of the FIXED (stationary) slack adjuster
- TDI_Joe
While doing a brake shoe inspection I found I have automatic adjusters on my rear brake. It appears to adjust when parking brake is applied while moving in reverse. My truck, a 82 KC SD 22 Feb build should not have these, apparently a non-stock addition. I checked my 1982 & 1983 FSM and found no reference to this setup.
No Worries Mate.
-Kevin
2003 VW Golf TDI 127K(uber car)55mpg@60mph
93 Dodge D250 5.9L cummins 111K
92 Honda 1500 GW SE 30K
82 Datsun 720 KC SD22 228K
-Kevin
That type of adjuster is not dependent upon the parking brake; when brakes are applied while moving in reverse, the lower edge of the rearmost shoe "catches" the drum -- it is self-energizing. If there is too much clearance between the rearmost shoe and drum (ie it needs adjusting), the movement of the shoe toward the drum pulls the adjuster cable enough to move the adjuster arm enough to "catch" the next ratchet tooth on the screw adjuster.
This is the way almost all drum brake self-adjusters have operated since the 1950s. Pull the rear drum off a Chevy or Ford or Dodge and you'll see substantially identical adjuster bits.
A prominent exception to the this self-adjusting bandwagon is the Gen1 Maxima Wagon (not Sedan) rear drums, which utilizes a mechanism that really does require the parking brake to adjust, and which will never self-adjust if the parking brake is not used. The Maxima's rear drum adjusters are not dependent upon wheel motion, only parking brake actuation. And they're always frozen up
LUCKY YOU ! Officially, those rear brakes became in 1984. So your shoes too are different than the OEM 1982/83 assembly. Drums too.TDI_Joe wrote:While doing a brake shoe inspection I found I have automatic adjusters on my rear brake. It appears to adjust when parking brake is applied while moving in reverse. My truck, a 82 KC SD 22 Feb build should not have these, apparently a non-stock addition. I checked my 1982 & 1983 FSM and found no reference to this setup.
AND... the automatic adjuster on nearly all truck and cars are made like yours. It could turn the adjuster only when you first hit the pedal while backing up. Notice the arm says "L" on the left design while the "R" on the right arm.
