water in diesel??
water in diesel??
whats he deal here.i know about adding water seporatly and recoment it .
from FREEDOM-MOTORS rotary diesel.
How can you expect an increase in power by adding water to diesel fuel?
Answer: Adding water results in further cooling of the charge and hence the rotor. The addition of water to diesel, gasoline or alcohol primarily benefits the engine by increasing volumetric efficiency by 20 to 25%. In the case of diesel, water also reduces the tendency to detonate and significantly lowers NOX emissions. California is making an 80% diesel 20% water fuel available at commercial filling stations.
Re: water in diesel??
davehoos wrote:whats he deal here.i know about adding water seporatly and recoment it .
I say ... people have personally injected "20-25%" proof and then told lies to others.
Has thanked: 5 times
There's some kind of diesel/water emulsion thing going around. It does work, I'm reading. Keeping the emulsion emusified is one of the tricky aspects. Injection system corrosion is another.
i injected large ratio of water electronically with an elderbrock unit.into a CA20 carby engine running LPG.
there comes a point that you loose so much power that you use more fuel.
i had a small water feed in my second LD20T,it reduced smoke.
peterr991
Post by peterr991 »
Diesel is fat. The fat does not mix with water.
AFAIK, in baking, eggs mix fat & water just fine.
However, diesel is not fat.
Users browsing this forum: No registered users and 42 guests
