TooManyIdeas wrote wrote:Ok so I don't NEED the ve pump right away?
Notwithstanding what has been said in other posts about there being no restriction at WOT, I would like to clarify that the pressure differential measurements I made WERE at WOT, but at low RPM. As the RPM climbed the differential diminished. The differential suggests a potential improvement in performance without the TB. That is as much as I can truly say until I can give some more numbers. Whether or not you should put a VE pump on a naturally aspirated SD22 is a guess only educated by the fact that Nissan went that route.
If you are planning to turbocharge, as you have said, I think you should do one step at a time. Either change the IP first or turbo first, but not both at the same time.
phil wrote:You don't [ditch the TB]... with the stock Bosch inline.
That is not entirely accurate. From what I can tell, all the pumps are practically identical. Even the cam is symmetrical front to back so that it can be reversed should the application call for a different direction of rotation (the lobe profile is not symmetrical). The big difference, and the point of concern for us, is the governor, which is a separate thing. It appears only on the road vehicles is the pneumatic governor used (correction?). So if when Phil says "stock Bosch inline" the governor is included, then he's right. You don't ditch the TB. Although when my "exception" is cited, the TB is only moved, not ditched, and the problem is not really solved.
The manual governor I have been dissecting is labeled for 650~1100 RPM. Despite the fact that the guy at the pump shop told me he thought it could be done (he had never done, nor seen it done before), and despite the similarities with the RLD-K type from the SD33T, the dissimilarities suggest to me that it will still take a bit of experimenting and modification to make a forklift or marine governor give the nice RPM range that we want. I would like to be wrong, but it looks like the only bolt ons will be the VE type or the RLD-K governor, which won't know whether it's hooked to a six or a four.
