Tires
Zoltan
Tires
Post by Zoltan »
I've never owned a rear-wheel drive car/truck before and I always thought that the driving wheels use up the tires faster. Is that true? Or it depends how much weight rides on the axles? I usually run the truck empty or just a long surf board on the bed, so most of the weight is in the front. The previous owner put a new pair of tires in the front and I am wondering if I should rotate them back.
- Zoltan -
'86 Ford Escort 2.0L Diesel
bacho
Post by bacho »
Na, unless you like burnouts the front tires wear faster becasue of worn joints, and scrub when turning. An old IFS is harder on a set of tires than a solid axle typically. As for performance, its also the normal to place the better tires on the front. In the rain if the rear tires brake loose you can have a hope of recovery using your front tires. If your fronts brake loose you have much less chance of recovery meaning you end up in the ditch.
1992 nissan pathfinder 4x4
1985 KC 720 4x4
1982 KC 720
