ld20 and ld20II difference?
ley_r
Post by ley_r »
What is the difference of this two? and is there any difference in PI
timing?
Member davehoos may be able to shed a lot more light on this, but from my perspective: the cam is chain-driven on the LD20, belt-driven on the LD20II. Oil pump moved from a pseudo-distributor drive on the LD20 to crank-driven on the II.
That's probably all I know.
ley_r
Post by ley_r »
What is the exact PI timing of LD20II?
1985 plunger lift at TDC
LD20II U11-0.69-0.77mm
LD20 C120[might be an old chain drive] 0.74-0.82mm
LD28 0.71-0.79 mm
1988 plunger lift at TDC
LD20II 0.73+/- 0.04mm[0.0287 in]T12/U11/C22
LD20IIT U11 0.64 mm at TDC.
RD28 C32 0.75 +/- 0.3 mm
TD42 0.74 mm [6" BTDC]
TD23 0.54mm 5" BTDC
TD25 0.77MM 7" BTDC
TD27 0.65mm 5" BTDC[inline pump 16" BTDC]
LD20 was a modified petrol engine.
LD20II
cam and cyl head design is improved.
the engine was designed to suit smaller/lighter FWD.
since been replaced with 2 generations of smaller lighter engines.
elbow
ld20 block
Post by elbow »
Dave you montion that the LD20 is a modified gas eng. Do you know what eng. block they took it from. Bob
L20B
you can change a LD20 back into a L20B/Z20.
but it has no oil seporator in the block for the PCV system.it has the casting shape for it.
the block is heavy contruction and from memory the pistons as smaller.
same deal as LD28 block modified to 3 and a bit litre L series drag race turbo's..
common practice to manufacture a diesel based on petrol engine so very little is needed to fit it in a standad model.
