Intake manifold cleaning
ley_r
Post by ley_r »
I want to clean the intake manifold of my Ld20 should i
remove also the exhaust manifold? and can i re use the gasket
if i remove only the intake manifold?
Re: Intake manifold cleaning
ley_r wrote:I want to clean the intake manifold of my Ld20 should i
I didn't at first, but . . . .
and can i re use the gasket if i remove only the intake manifold?
Probably not. I took only the intake off at first, but when I decided I had to clean out the intake ports (using aerosol carb cleaner, a brass wire brush, and Shop-Vac with a garden hose duct-taped to the end, to get right to the valve stems), I unbolted the exhaust manifold and I think I just pulled it back from the head -- I don't recall taking it off the headpipe, but I really don't remember.
ley_r
Post by ley_r »
Thank you for fast reply, i think i should clean this
due to black smoke and loss power in up hill.
