FAQ has been updated
Major updates to The FAQ include:
  • Added TOC to top of page;
  • Moved some items around into different categories;
  • Added "fuel filter" placeholder;
  • Added "acronyms" section;
  • Added link to FSM errors thread;
  • Added "parts catalogue" info;
  • Updated PS pump info in "Parts Availability->PS Hose" section;
  • Added "Brakes" and "Brakes->Wagon rear brakes" section;
  • Added "Common problems" section
Doesn't sound like much, but it took three hours . . .
I could use a volunteer to write up something about the fuel filter (Nissan part No., aftermarket part Nos, change procedure, change interval recommended by Nissan, etc.). Email it to me (asavage@iname.com) or just start a normal thread and put it there.
And of course anything that you think should be in the FAQ, let me know; it'll go on the to-do list for next week.
19-Feb-2006:
Added "Model Year Changes" section.
This section really needs fleshing out. Look over what I've put down so far, and buzz me about what I'm missing. I'm thinking there was a change to the power mirror controls in there somewhere (from '81 to '82?).
20-Feb-2006:
Fixed several typos;
Added part nos. for torque damper, PS hose;
Consolidated the fix info for the "break in wire harness" repair, and fixed links.
24-Feb-2006:
Added Common Problems->Door Cracking.
25-Feb-2006:
Changed PM switch MY change from '82 to '81 (Thanks, Steve!). Parts Catalog indicates Mar-'83 changeover in Wagons but Jul-'81 changeover in Sedans. The Sedans date is more likely correct for both.
27-Feb-2006:
Changed "8mm" to "7mm" for the head size of the small bolt on the IP belt cover;
Changed some of the text describing the front crankshaft seal R&R;
Added a paragraph in the IP Belt section, and a list of items to check/replace.
26-Mar-2005:
Updated MY change for 1983: A/C switch differences;
Updated "MY changes" to remove "Under Construction".
11-Apr-2006:
Added "All dash warning lights stay or or come on intermittantly" to "Common Problems"
23-Apr-2006:
Updated MY changes for 1983: Dome light switch.
06-May-2006:
Updated MY changes for 1983, 1984: Grille, badge, and hood ornament
28-Aug-2006:
Updated "IP Belt Maintenance": IP Belt and tensioner prices, and corrected the Belt's part number.
18-Oct-2006:
Updated MY changes for 1983: engine oil cooler redesign.
15-Mar-2007:
Updated MY changed for 1983: oil filter revision to combo full/bypass type.
25-Mar-2007:
Added Common Problem link for "Door unlocked but will not open" (Thanks, goglio704!)
11-May-2007:
Added links for various MY changes.
Added cluster differences for '83 MY changes
Added 1983 oil filter difference for MY changes
