OEMSurplus is scrapping NOS Nissan/Datsun parts
As noted elsewhere, OEMSurplus.com is discontinuing selling off the NOS Nissan parts it's accumulated.
http://oem-surplus.com/nwp/slMaxima.htm
NOTES: — The items in BLUE are part of the first culling. They will be inaccessible or unfindable first. In other words, they are the first ones to be burned/scrapped/dumpstered/etc.
— To view application/data information and/or pictures, go to the regular parts pages under the appropriate model and hunt down the part number there.
— Nobody here has the time to answer simple application questions that is already posted on the regular parts pages, so please, for your information, find the number on the other pages (or other sources which you may have access to) before contacting us.
— Quantities in this list may be way off but most of the time should be accurate.
— The culling of the warehouse has begun. Soon the list will be inaccessible as the parts will have been burned/dumpstered/scrapped/etc. So, you need to grab these pieces ASAP.
[list of part Nos. to be scrapped follows on that page]
I am not in a position to buy much non-essential stuff right now, so as a spectator . . .
Kassim, how 'bout the air filter assy? L24e, 16500-V2725
LD28 injectors return line ("spill tube"), all years, 16671-V0700
(whoops, that one's not on the scrap list, but it is available)
1981-82 Cold Start Device ("CSD") (will not fit 1983), 16830-W3300
(I ought to pick that up myself, as mine doesn't work on my '82 Wagon)
"Knob Choke Control" for L24e & LD28 . . . ??? Anyone know? 18415-H8610
Torque Converter Housing (L3N71b), 31300-X6600
Drum Assy Support (L3N71b), 31384-X8603
Mud Guard Set, RH Front, 81-4, 63850-W2400
[no pics]
A couple of front seats (no pics) from Gen2 Maximas, which someone pointed out fit pretty darned well in the Gen1s
http://oem-surplus.com/nwp/maxima6.htm
FR Seat Cushion Assy-LH (8107 84 Maxima : S.DX), 87350-W3210
[no pics]
Roof (?), 73112-W1030
http://oem-surplus.com/nwp/maxima4.htm
Side Member RH, Wagon only, '83-84 (8207 84 Maxima : W), 75510-W4800
AC Hose (L24e), (8107 8210 Maxima : *S+W.L24E), 92490-W3200
AT gear carrier (planetary gear set) (fits 720s too), LD28 version I guess,
8211 85 720 Truck : AT Also: 81-82 210;
8007 84 Maxima : LD28.AT Also: 87-89 Mini-Van
8310 88 200SX : CA20E.AT
8511 8908 Truck : Z24.AT.(F4+R4)
http://oem-surplus.com/nwp/picpages/314 ... 1420-X6100
I was actually just on OEM surplus trying to find some stuff that i could get, but im kinda on a budget now. So, im seeing if I can bite down some important stuff that cant be found from FLAPS for my gasser. Like ECU's and mabye that intake box, even though I dont think I can imagine breaking one.
