1985 diesel sentra
leadpaw
1985 diesel sentra
Post by leadpaw »
CD17 sentra 160k miles on it.engine pics later.
1985 diesel sentra
Re: 1985 diesel sentra
leadpaw wrote:Image
I must say, this is rather striking photography.
You will want to update your Profile (click on Profile at the top of any page) and add you Location. It will save Qs later.
leadpaw
Post by leadpaw »
Autox and engine pics :)
1985 diesel sentra
leadpaw
Post by leadpaw »
hmph forgot i had a post here, well at 190,000 miles it started misfiring heavily even when warmed up.. one of the injectors failed.
tips are heavily eroded
My injector pump was also leaking like a sive, luckily i found a brand spankin new one from a local packrat and got it for 200 dollars.
1985 diesel sentra
leadpaw
Post by leadpaw »
Timing set at 1.00mm.
Setting the injection timing on the cd17 is an interesting endeavour, you have to take out the rear water pipe, thermostat housing, injector lines, starter wires, and other surrounding wires.
The diesel shop I had sent my injectors to bead blasted my injector housings which took off the plating so i painted them to prevent corrosion.
She runs amazingly well now but still needs the valve clearance adjusted, 3 of the valves are out of spec and 2 others have no clearance.
used the following tool:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0037223315
1985 diesel sentra
leadpaw
Post by leadpaw »
found a really low mileage(from rebuild) rn4 on thursday, that has been sitting on a shelf for 9 years, or at least that was what was claimed by the seller, i dont believe him... There is some rust on the differential bearing from sitting for such a long time but otherwise its a nice looking transmission.
1985 diesel sentra
leadpaw
Post by leadpaw »
HAHA, turns out the new trans I got IS a 5 speed, i should've saw that when i took it apart. I Installed it today and was surprised that there was an extra gear xD.
1985 diesel sentra
!Score!
240ZD
Post by 240ZD »
Your car is SO BADASS. All you need is a nice little turbo setup and that thing will be epic.
