Exhaust theory
Exhaust theory
Here's a link to a couple pages about how/why exhaust systems work and help an engine breath. It says some interesting things about the relative importance of the exhaust system vs. other tuning improvements in getting more from a particular engine. Also note the possible use for a "resonator", positioned a certain distance aft of the collector but before any mufflers - it terminates the tuned length so that whatever comes after that (mufflers) doesn't mess up the tuning of the headers and secondary pipe(s).
http://www.superchevy.com/technical/eng ... page1.html
Cheers, Rufus
windsock
Re: Exhaust theory
Post by windsock »
rlaggren wrote:Here's a link to a couple pages about how/why exhaust systems work and help an engine breath. It says some interesting things about the relative importance of the exhaust system vs. other tuning improvements in getting more from a particular engine. Also note the possible use for a "resonator", positioned a certain distance aft of the collector but before any mufflers - it terminates the tuned length so that whatever comes after that (mufflers) doesn't mess up the tuning of the headers and secondary pipe(s).
Cheers, Rufus
Will have to read that linked information a few times to interpret it relative to the LD28. What does it mean for optimising a pipe size for the diesel engines?
Nothing particular... <g> It's the concepts that I'm looking at. Although, it may mean that that resonator next to the tranny was doing something - as I recall the LD exhaust manifold actually has some shape and had a 3-2-1 form. A turbo may throw all this out the window because it probably evens out any pulses pretty much - puts the breathing upgrade ahead of the cyl instead of behind...
You can take the "breathing" calculations for the Datsun gasser 6 and use that as a starting point (lots of info on those engines); probably we're just interested below about 4500rpm. The diesel valve timing must be different and s/b available in the FSM to compare. I figure it's more "conservative", less overlap than the gasser builds, so any exhaust tuning would have less affect. But I found the relative importance of _any_ exhaust tuning vs. intake tuning most interesting.
Users browsing this forum: No registered users and 35 guests
