Flywheel bolt torque?
minimog
Post by minimog »
Hi, does anybody know the torque setting of the flywheel bolts for an LD28 engine with manual transmission. I've done a search of the forum but couldn't find any info.
Thanks, David.
I'll dig out the FSM and see what it says. Prolly get back to tomorrow.
101-116 lbs-ft for the flywheel bolts, from the FSM.
minimog
Post by minimog »
Thanks, Rufus.
That seems a little high, but I checked it back and forth... Might want to do a reality hit with somebody that installs manual trannys. It's been years since I had an engine apart and I don't recall the torque ballpark.
Best luck. Rufus
ANGRYLANCE
Post by ANGRYLANCE »
Heres my method: Red loctite and about 5 raps with an impact wrench.
240ZD
Post by 240ZD »
My Chilton manual says 94-108 ft/lbs for the gasoline L24-L28, and a bit less for the V6.
