PS idler pulley
PS idler pulley
The power steering pulley is the same diameter and belt size as the air conditioner pulley and appears to use the same bearing, BUT on my engine:
The PS pulley is close to 1/8" thicker and this means that if you want to swap them in an emergency you must shuffle those washers and bearing shields you find in front/behind the pulley carefully to get the bearing shields at the proper clearance and to get the pulley to line up with the engine pulley and the PS pulley. I think the rear spacer washers are 7/16 and the front 3/8 (of course not really cuz they're metric...). I say "think" because I didn't find any to fit and had to ream out some 3/8" to suit just to get the thing done so I could go get the right part.
Somewhere here I a saw Q about whether spacer washers were OEM. FWIW, I think they are.
I got a new bearing w/out issue over the counter at the local bearing shop; but the counter guy shoved a Chinese brand at me the first time; it took two tries to get a decent one - cost all of $9. Last year I had bad luck w/Chinese bearings straight out of the box so now I ask for better.
I'll edit this to show a part number in a day or two.
