nissan 720 diesel SD25 4x4 $2500
gresh125
Post by gresh125 »
1984 nissan pickup 4x4 disel SD25 ve style injection pump not inline. has power steering. it runs great .no problems. trans just rebuilt 50 miles ago all brand new bearings inside, seals, gaskets, new main shaft and counter shaft
and idler gear. has a brand new clutch and throw out bearing and input shaft bushing. new slave cylinder. so the drive train is good all the way through .it shifts great through all the gears . it comes with the real deal service manual, brand new starter. brand new optima redtop. has two custom intergrated gauges in the dash gauge cluster for oil pressure and engine temp. truck does need a cleaning but there is no rust. this is my daily drive but my son has arrive 2 weeks ago so we need more of a family vehicle so this one has to go. you could convert this to run on vegg. this is a great runner that will serve you well. I get about 28-30mpg highway located in Poulsbo WA has 164000 on the OD. CALL SCOTT 850-499-0996
asking $2500
1984 nissan 720 4x4 sd25 ve rotary pump
dn29626
Post by dn29626 »
Are you saying this is a factory diesel 4X4?
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
dn29626
Post by dn29626 »
Anderson , SC
Since Fall 2009
gresh125
Post by gresh125 »
no it not factory diesel was a gasser
