Wow, very nice job Dave. Loving the bling newness of everything. Didn't realise it was such a tight fit to get everything in the tunnel of the truck cab. Really looking forward to hearing the video now as dslsmoke said, another one please.
Very interesting set of photographs on second look.
Is that a custom made inlet manifold? Would be nice to have such easy access to all exhaust and inlet bolts like you have.
Liked the breather from the top of the valve cover. Where does that go to? I have just connected up a catch can to seperate the breather from the inlet. Just wondering what you've done.
What turbo are you using? I have been told to look for a T25 from a Nissan CA18DET running 9psi. I have my eye on a 280ZX manifold off an L28 but if I use that my downpipe gets very close (too close I think) to my clutch slave cylinder and piping. I could 'J' pipe it off the manifold to sit further forward though. Other alternative is to make a custom exhaust manifold out of steampipe in a semi-header fashion.
What size intercooler are you running?
Finally, from a 4X4 perspective, I'd be wanting to sheild that sedimentor beneath the exhaust pipe if I was you. I have seen branches and other stuff get twisted up under my flat deck tray by driving over it. I would think a piece of flat bar bent in a similar shape to your mounting bracket and then mounted opposite would suffice.
Heck, the more I look at all the nice fitting work you've done on your truck and the painting and the time and effort, wow, top job. A shame we can't go wheel sometime, I'd love to hear and see this mog out there.
Thanks for posting.
Phil
