L28 turbo oil pump
minimog
L28 turbo oil pump
Post by minimog »
I seem to remember reading on here somewhere that this pump can be used on the LD28. Can anybody confirm this?
Thanks, Dave.
240ZD
Post by 240ZD »
Hello!
I currently have an L28 turbo oil pump on my LD28. Found it in a junkyard for 25 bucks or so. It is a direct bolt-on, and uses the same gasket.
Swapping to the turbo pump significantly raised my oil pressure needle off the 0 mark at idle, which is nice because as a consequence I don't nervously stare at it as much. At highway speeds there is also a pleasant increase oil pressure.
