New/Replacement Seats
I was just wondering what folks had to say about replacing the seats in the 720 King Cab.
I'm hoping to find some seats that are better quality/comfort than the stocks seats.
My girlfriend and I are both tall so we need to keep the seats as low profile as the stock, though a little lower would be great...
I've also contemplated getting seats (at least a drivers) made though I'm not sure exactly how much that would cost....
I've already come across one forum posting on seats but was hoping for more input:
http://nissandiesel.dyndns.org/viewtopi ... ight=seats
Any feedback is much appreciated
1982 720 SD22 CA Emission
Isuzu ( 90's models ) are considered to be a drop-in replacement (all bolt holes line up).
Neon seats (2000's models ) are close, front holes line up good, back holes require holes to be enlarged or slot just the inner rail hole ( I installed neon seats and slotted the inner rail hole ).
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
Anderson , SC
Since Fall 2009
I just got a set of really nice condition '91 Toyota Camry seats, for half price at the junk yard!
The driver seat has a front and back tilt and a lumbar- very comfy. Though putting them in is going to be a PIA. None of the brackets match up. Rail system is much wider than stock seat.
I will have to custom mount it. I'm installing 1/4" plates inside and outside of cab frame. It's a bit overkill, but it will ensure the seat bolts will never tear through the sheet metal frame.
I will also need to shift the seat belts back to accommodate the new seat position- tall people need more leg room.
Seat Mounting Rail Structural?
I want to make my seats as low as possible, and that would mean cutting out the rail you mount the front bolts for the seat.
Is that mounting rail a structural support or does it only serve as a mount point for the front seat bolts?
I know this seat install project is a gonna be a big hassle when so many other seats will go in with far less work. But I am pretty tall as is my girlfriend, so finding a seat that is actually comfortable is worth it- We are taking my the truck on a cross country trip 6,000 + miles in a month!
Wowser, Howser!
Yes, those rails are, sadly, part of the cab's structural integrity.
If you figure a way to eliminate them AND rigidify the cab, please (OH, PLEASE, Mister) let the rest of the planet hear about it.
Thanks,
Thanks,
Wowser, Howser!
Cmdr. Ron
Cmdr. Ron
