It still needs to be cut and buffed but its good enough for the girls I go out with!
Not to horn-in, but I put,,,dn29626 wrote:I looks much better.
You mentioned in another post that your tires rub. What size are they so i will know what size is too big?
I have 205/60/15 on mine. No rubbing.
On these trucks i like wheels that give the truck a wide stance and tires at an appropriate width to have aCmdr. Ron wrote:Not to horn-in, but I put,,,dn29626 wrote:I looks much better.
225/60R16 on the front - No Rub EVER (1" taller than stock)
245/70R16 out back - No Rub EVER (29.5" = 3.675" taller than stock)
These are on Factory Option Isuzu 6 spoke 7 x 16 Aluminum wheels.
215/70R16 rubbed SLIGHTLY at full turn both ways (2" taller than stock)
215/65x16 would clear (1/2" shorter), but when repairing some rust from a coolant leak, I opened-up the zone a bit.
New rear tires are 245/75x16 (30.5" = 4.675" over stock)
Run the numbers to see effective final drive ratio is roughly 3.46:1 & quiet on the freeway.
Oddly, I could feel the extra drag with the wider tires in front - especially on our sand road.[/img]
