I was going across country in my truck. Everything was fins until a calf ran out in the middle of the highway... Everybody is fine, the calf died quickly, by my radiator is shot.
I was hoping someone has a spare...
Or if someone knows where I can get one without spending over $400 dollars for one.
Any info is always much appreciated.
I need a Radiator Bad
Well, kinda depends where you're located, as far as local sources go. An independent or shade-tree shop might get you going for a little less. If you can weld (wherever you are), have a junk yard around and a tape measure handy you can probably find something you can fit on that will do the job...
IOW, not rocket science but there's work that's gotta be done when you have an old vehicle and can't (or don't want to) order parts out of the catalog. You could probably skip the fan (but gotta have all the belts working) if you really had to - just watch the temps and don't drive slow too long. But that can get stressful and you might destroy your engine if you zone out at the wrong time.
Good luck.
Good luck.
justanother54321
