Can't get it started
diesel4me
Post by diesel4me »
Well I have a 84 with the SD25 and I can't get it started! So far I have replaced both fuel filters, the lift pump, rebuilt the injectors, and replaced all the rubber hoses under the hood. Is there anything that I'm missing? I can get it started by pulling it and starting it that way and once it starts it runs fine with no smoke and it has plenty of power. If I shut it off while its warm it starts up no problems but if I leave it sit for about 30 minutes it won't start again??? It turns over fine but thats it... has anyone had a problem something like this? Any help will be great.
Thanks, Jordan
dn29626
Post by dn29626 »
I think the glow plugs are not working.
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
dn29626 wrote:I think the glow plugs are not working.
X2
diesel4me
Post by diesel4me »
Well I checked those too, But I'll check again to make sure. Can't hurt.
diesel4me wrote:Well I checked those too, But I'll check again to make sure. Can't hurt.
I only need to park for about a half hour in the hottest weather and I have to glow the engine for five seconds to get it going again. I got rid of all my glow controller problems by ripping it out and putting in a push button actuated relay. I'd just about bet money that your glow plugs aren't deploying.
N_R
diesel4me
Post by diesel4me »
Well you guys were right. I forgot to mention that I had replaced the GP's last winter so I didn't even think about those. But I tested to see if they had power and they did, but out of curiosity I pulled one out and tested it...and nothing? All four of the GP's weren't working. So I put all of my old ones back in and it started! So thanks for all the help pointing me in the right direction.
dn29626
Post by dn29626 »
Good to hear it is starting. Are all four glow plugs working now?
What brand are the newer glow plugs that failed?
Anderson , SC
Since Fall 2009
diesel4me
Post by diesel4me »
yeah all four GP's are working now. The new GP's that I bought were NGK rated at 10.5v so i'm wondering if there is something else wrong with the truck to burn out all four of those plugs?
'84 KC SD25 2wd/ '66 Nissan Patrol, gas.
diesel4me wrote:... so i'm wondering if there is something else wrong with the truck to burn out all four of those plugs?
Likely not. Those plugs are not able to take the extended run-time that the timer gives them. A friend who kept the timer going in his truck would find himself replacing a glow plug or two every year or so until he gave up the truck. I left the timer behind when I put my current truck together and have never blown a plug in 7 years driving.
