I bled the injection pump lines and the engine fired up with about 30 minutes of work.
I'm wanting to build a 10,000 watt generator and I have this Nissan SD-22 engine and a Datsun A14 gasser carbed motor, and am not sure which one would be better to use.
The SD-22 is guessed to have 110,000-115,000 miles on it, and is in pretty good shape. I know basically nothing about this engine other than it sat for around a decade before I bought it. It needs fresh oil and a few coolant lines.
When I first fired it up I let it run for about 20 minutes and had a few pinholes in some of the rubber water lines on the side of the block. I do not have the DPC module, and have to manually control the injection pump.
The A14 has 160,000 miles on it and munched the transmission, but runs pretty good. It was in my 81 Datsun/Nissan 210.
Any advice for building a generator? It needs to be smaller so I would have to remove the transmission and build a plate to mount the starter on to, which is no big deal.
Any pictures of any SD powered generators?
We are a race team and are looking to build a generator that can run at idle and power our equipment at the track without having a 5000 watt generator blasting our ears out all day... our race cars do that enough!!! I figure with an SD-22 or A14 with a couple mufflers added on, it could run just above idle and make all the power we need to run a small welder or other equipment (lighting, fans, computers, etc...)
Pictures:
