New Member, needs FSM
gromit
Post by gromit »
Just joined, and just acquired a LD28 engine and auto trans. Thinking over what I want to repower with it. My last swap was a Isuzu 2.2 into a '28 Chevy coupe. Ended up a little lacking in power, so put a Eaton (roots type) blower on it.
One of the first things that I need desperately is a factory shop manual.
Checked Ebay the last couple weeks, but didn't see any. Any members have an extra that they would be willing to sell?
Gromit
minimog
Post by minimog »
Al's online FSM for the LD20 & LD28.
http://asavage.dyndns.org/Nissan/displa ... Page=0-001
:D
gromit
Post by gromit »
That's a great asset
Thank you!!
I would still like to obtain the whole "82 manual to help with identifying where the various hoses etc went on the donor car. Also info on the automatic trans- unless that is covered in Al's download.
Again, thanks to you both--
Gromit
minimog
Post by minimog »
Datsun/Nissan 810 FSM for LD28-
http://cgi.ebay.com/ebaymotors/1981-Dat ... 27be1fb921
Datsun/Nissan 810 FSM, covers rest of the car (transmission, drivetrain, electrics etc.)
http://cgi.ebay.com/ebaymotors/Datsun-1 ... m1dba9326a
I shouldn't worry about the year, 81-82 is much the same.
gromit
Post by gromit »
Thanks Minimog for the Fleabay links, but one of the reasons that I want a FSM is for automatic transmission info, and from what I understand reading here the 82 trans is a lockup, the 81 is not.
Gromit
gromit
Post by gromit »
Got my "new" engine running, and and have a headgasket on the way,
just in case. Looking it over to see what unnecessary (to my needs) items I can remove- I realized that my crankshaft pulley damper is missing its outer ring.
Anyone have a spare that they would be willing to sell? Failing that, could someone tell me the OD, of the outer ring--and if is stepped what both diameters are. I will then make up a new ring and a fixture to insure concentricity, remove the old rubber and recast with urethane-- but hoping to avoid all that work.
Still watching fleabay for an '82 FSM
Gromit
gromit
Post by gromit »
bump
