Hi, Iam implanting a SD25 into my SWB jeep. Need to know the purpose of these 2 tubes from the Kiki pump. I know one is connected to the air intake to open a butterfly. What is the other tube for and where is it supposed to be connected. What about the second butterfly? how does it open up. Thanks.
https://picasaweb.google.com/1146916185 ... 5093073890
P.S- The pic shows two temporary rubber tubes, one goes into the butterfly just below the air filter, the other? By the Iam planning to fix K&N air filter.
Don't know where the tubes from Kiki should go :-(
Good Day
I have not seen that option on any of the SD25's here in Canada and the SD22's had a different set up with altitude compensator etc.
Maybe one of the Ausi or Kiwi guys can suggest something.
I have the VE style pump on my SD so I am not much help to you.
[quote="plenzen"]Good Day
Paul[/
Thanks a lot Paul. Got a bit of information. One tube goes to the throttle shutter, other to the air inlet. Hope this is correct.
Dr.Jones
Paul[/
Dr.Jones
- ecomike
Both go to the throttle body, but on opposite sides of the Throttle plate. The top one may actually go the air tube between the throttle body and the air filter assy IIRC? Not sure which is top and bottom, but if you get them on the wrong side It should be obvious very quickly, LOL!
The differential absolute air pressure on each line across the throttle plate, operates a leather diaphragm in the Kiki body. Some of the old threads here on the SD-22 Kiki pump should show the details.
Mike
Mike
- ecomike
OK, looking at the pictures you posted, the rear most line, on the rear of the injector, which is also the bottom metal line goes to the engine side of the Throttle body, the top metal line goes to the air filter metal inlet housing.
Mike
Mike
