HELP :( TD27 turbo puking oil out exhaust side of turbo
jiggseob
Post by jiggseob »
TD27 in a Terrano.
Exhaust manifold has light coat of carbon at exhaust ports. Exhaust downstream of turbo is totally oil-puked. Seal is quite obviously toast.
Sometimes, thats an indication that bearings in turbo are too wobbly, which takes out seal. Replacing seal alone would probably be futility.
About 1 qt of oil per 300 miles going out the tailpipe.
Does anyone have any idea if seal-bearing kit thing is a possibility or does anyone know where to buy a replacement turbo or overhaul kit? Is there another donor application that can provide a replacement turbo?
TIA
Jiggs
Try these guys
http://www.gclfuelsystems.com/
Not sure where in Alta you are but they have shops in Edmonton and Calgary.
HTH
