SD-23 ENGINE ID LOCATION.
STOPBATH777
Post by STOPBATH777 »
Hello,
I just purchase a sail boat with a SD-23 marine engine. Where is the data info stamped on the engine located?
I need a new pan gasket but the parts suppliers want a car/truck make and year to locate the gasket part number.
Denny
Denny
Sailing Lake Mead, Nevada
Some of the marine versions of the CN433 ( SD 22) had a plate riveted to the side of the valve cover at the back on the pump side.
I would think that there is only one gasket and the the "flange" will be the same no matter what the sump look like
Any year/model will do
I M O that is.
HTH
Further search and found that perhaps Nissan Part Number is
11121- V1700 gasket
Picture here : http://www.yiparts.com/Part/en/n/NEWBBSC
Appears to be the same part number for SD22 and SD25
HTH
