LD28 Tachometer Probs
buddabeast
Post by buddabeast »
Hey diesel fans, I've got a Nissan Laurel 85 with the LD28 but the standard tachometer has stopped working, has been out for a while now. When I first bought the beast it wouldn't work until the engine warmed up. So maybe after 15-20 mins the tacho needle would start moving. Anyway now it's dead.
So I'm wondering if anyone relates to this? I see some threads on rigging a new tachometer or replacing the EGR sensor.
But where would a good place be to start troubleshooting? How can I test if my EGR controller is still working? Or where it even is? I'll have a look under where I pull the bonnet (hood) lever. If that's working then I could test the EGR sensor two cables with a multimeter? I want to get my rpms back badly and would prefer the OEM tacho.
Cheers!
Here are links to threads on this forum that may help you.
http://nissandiesel.dyndns.org/viewtopi ... t=egr+tach
Generally with electrical stuff you start with the wiring, see what's come loose, broken. Then with voltages; make sure the ground for your multi meter is securely attached to the frame, battery neg, something...
bogs777
Post by bogs777 »
wow, my laurel didnt came with tach. youre fortunate. also my EGR was toasted when wires going to the glow plugs shorted. my EGR is completely out. also trying to figure out what would be the most cost effective way having a tach from the steps given.
C32 Laurel, LD28, Black/White, 330k
http://www.gofundme.com/7artao
dn29626
Post by dn29626 »
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
