Brake Bleeding
Dr. Jones
Brake Bleeding
Hi all. I hope everything is going well.
I can't seem to build pressure in my system to bleed the front brakes. The back bleed fine, but when I moved upfront I could not build up pressure. Any ideas to what could be going on? I replace the master cylinder, should I have bench bleed it?
'82 Maxima Sedan x2
- Has thanked: 1 time
ALWAYS bench bleed a new master cylinder...
If you replaced it without touching the calipers, you can sometimes get away with some 'cheating' by removing the front wheels and then collapsing the caliper pistons back into their respective housings with judicial prying. This forces fluid back up into the master cylinder causing air to be displaced and likely making it possible to carry on with a normal bleeding...
N_R
N_R
Dr. Jones
Dr. Jones
Duaneclark
bleeding brakes
Your master cylinder should force fluid through either of the front calipers with the bleeder screw open. Better if master is pre-bleed. If you're pressure bleeding from the master cylinder, fluid should come from the caliper, even if the proportioning valve NPT is stuck one way or another, it couldn't be stuck all the way one direction. If fluid doesn't flow, look for clogged bleeder screws, (remove them), clogged line, (flex or pipe), or go to the master and make sure fluid comes from the front brakes port. It could be a defective new master cylinder. Good luck! Duane
Duane
Dr. Jones
Users browsing this forum: Amazon [Bot] and 24 guests
